miss at idle
Old Apr 17, 2011 | 03:07 PM
mike wolfe's Avatar
miss at idle
i just bought a 06 2500 and it has a rough idle and a popping sound in the air cleaner box any ideas thanks for any help other than that the truck runs good and gets good fuel mileage
Old Apr 17, 2011 | 05:02 PM
Adaminak's Avatar
Need some more info: Mileage, any aftermarket pieces/parts, auto or manual? You can complete this info in the signature portion of the "User CP" so you won't have to add it every time.
Also, does the rough idle happen when warm or when cold? First start of the day or anytime? If you feather the fuel pedal, does it smooth out?
Old Apr 17, 2011 | 08:26 PM
mike wolfe's Avatar
no aftermarket equipment, truck is automatic, 230k and it idles rough at all times do not feel it after idle
Old Apr 17, 2011 | 08:57 PM
509Diesel's Avatar
Any codes at all? Has it done this since you bought it? Does it feel like you are lacking power?
There is a lot of knowledge around here willing to help, but the more info the better.
Old Apr 17, 2011 | 11:53 PM
Adaminak's Avatar
First step is to eliminate the easy stuff. Replace the fuel filter, check that the air filter is good, additive in the fuel (I like the Power Services grey bottle for daily use and the Redline Diesel Plus for cleaning), and make sure the lift pump is working. The '06 has a lift pump in the fuel tank, and they don't normally fail, but 200K+ miles can take a toll on anything. When you crank the key to run, you should hear the liftpump whirring away for about 20 seconds or so...
Also: Any white or grey smoke? Is the oil thin or does it smell like diesel?
Old Apr 18, 2011 | 02:55 PM
johnh's Avatar
if that was a gas engine, i would say a bad intake valve, but i don't know if a diesel would do the same
Old Apr 19, 2011 | 10:32 PM
mike wolfe's Avatar
i was thinking intake valve but have not had time to do any checking, truck has plenty of power and no other problems except the slight miss at idle and the noise coming from intake air tube
Old Apr 21, 2011 | 05:17 PM
JohninLV's Avatar
My 03 auto started doing that a few years ago. I tried 2 cycle oil and additives and it would run fine for a while. by searching the forums I found some have had problems with the Fuel Control Actuator (FCA) sticking. I found a new one on ebay for less then $100. It took 10 minutes to replace and the truck hasent missed a beat since.
gonehuntin
Mar 13, 2006 12:28 PM
NJMurvin
Jul 15, 2004 11:28 PM
NOTSTK
Apr 22, 2004 10:58 PM
fish01
Apr 21, 2004 12:15 PM
tbourque
Feb 19, 2004 12:57 PM
