Mileage
Old Sep 12, 2005 | 07:44 AM
dragan's Avatar
Mileage
I can't remember what it is called when on the highway up to speed the engine stop using a number of cylinders to increase mileage. Anyone know if this can be retrofitted and does dodge/cummins have this in new trucks?
Old Sep 12, 2005 | 09:09 AM
djbikeman's Avatar
On the Hemi, Dodge calls it MDS, Multi-Displacement System. It shuts down 4 cylinders to improve mileage when the power isn't needed. Not available on CTD. There is more to it than just computer programming. I'm pretty sure you don't want to shut down fueling to 1/2 of the cylinders on a CTD.
Old Sep 12, 2005 | 09:24 AM
dragan's Avatar
Mileage
Thanks for the answer I figured it was something like that
Old Sep 12, 2005 | 09:37 AM
drew03's Avatar
i dont think it would run very smooth
Old Sep 12, 2005 | 09:59 PM
Jc9995's Avatar
Cant be done
on variable displacement engines, the valve train on the engine uses electric solenoids and/or linear actuators for the push rods, or on the Lexus system there is no cam, the valves are completely moved by actuators. This gives variable dwell, valve timing and displacement. The valves are held open so as not to require power to compress the air in the cylinder that is not being used. Not much to go wrong on those systemes eh?
Old Sep 13, 2005 | 06:57 AM
bluepp's Avatar
Remember when Cadilac put out the 4-6-8 back in the 70s?? Nobody could make it work right and they dumped it. But with todays computers and the electronic actuaters instead of cams it should be more succesful. Untill the actuaters start to go bad. But then injectors work.???
Old Sep 13, 2005 | 07:16 AM
T & T's Avatar
The Hemi "C" motor does have a cam..
http://www.allpar.com/mopar/new-mopar-hemi.html
Old Sep 13, 2005 | 07:25 AM
Boatnik's Avatar
All those in favor of saving fuel raise your right foot.
Old Sep 13, 2005 | 08:57 AM
SBishop's Avatar
Second what Boatnik said!!
GLHS
Feb 13, 2009 07:58 PM
zack birge
20
Jul 11, 2008 10:29 AM
slowstang232
Mar 31, 2008 08:23 AM
Kman9090
Sep 19, 2006 11:25 AM
TxDiesel007
17
Jan 17, 2006 02:54 PM
