Micron Ratings
Old Jan 9, 2011 | 05:22 PM
john40's Avatar
Micron Ratings
I'm confused. What is the difference between nominal and absolute micron ratings? I'm currently running an auxiliary Wix 33528 fuel filter rated at two microns. Is this an accurate number?
Thanks-John
Old Jan 9, 2011 | 08:42 PM
C Schomer's Avatar
The difference is several microns. Absolute is the larger size the filter will trap at 100%. Nominal is the smaller size the filter will trap but at a much lower percentage. I don't know how they come up with the exact numbers for the nominal rating. I only believe independant tests. Filter mfgrs jack with their numbers something terrible! Craig
Old Jan 10, 2011 | 12:32 AM
Thundercraft's Avatar
mostly agree - Absolute is 98.7%.
Nominal, like you say is a smaller particle size - but it's a useless rating as there's no real test criteria to come up with that rating.
Why do most filter mfgrs us nominal (remember, if they don't say it will be a nominal rating) ratings? Probably because it makes their filter look better than it really is.
What you want to know is what is the micron rating that the filter will probably pretty much clean up everything vs. what is the particle size it might catch.
Old Jan 10, 2011 | 12:39 AM
john40's Avatar
Thanks for your replies-John
03RAM2500
Jan 11, 2009 05:21 PM
Drafter
Jan 24, 2003 05:20 PM
Hummin Cummins
Dec 2, 2002 04:26 PM
latitud_rt
Oct 23, 2002 10:19 AM
