Mega Cab driveline question.
Old Jan 15, 2007 | 01:01 PM
1stdodge's Avatar
I have a 06 Mega Cab 2500 4wd.
I was under the truck today checking fluids and I noticed that the driveline will move around in the carrier bearing. If you grab the driveshaft and move it side to side. At least I think its a carrier bearing. Its a black rubber mount that the driveshaft passes through.
Is this normal?
I would think all that flexing would cause a lot of vibration and wear.
Any input is appreciated.
Old Jan 15, 2007 | 03:11 PM
Erska's Avatar
I highly doubt there is anything broken. My 99 does the same, at least it should be doing it but I dont know 3rd gens, but I'm pretty sure it's normal.
Old Jan 15, 2007 | 03:58 PM
djbikeman's Avatar
It's normal. If the carrier bearing goes bad, it will start clunking. There needs to be a little play. the axle and pumpkin are not static. As the axle moves the carrier bearing helps the driveshaft adjust to changing angles, driveshaft extension etc.
dockrocker
39
Apr 24, 2011 09:43 PM
jimbo486
13
Nov 5, 2009 09:17 AM
drewallen42
Jun 11, 2007 09:23 AM
jrussell
May 8, 2007 09:24 PM
4x4dually
May 11, 2006 10:46 AM
