Manual tranny fluid amount
Old Feb 16, 2006 | 04:10 PM
Dorkweed's Avatar
Muted User
From: "The Peoples Republic of Illinois".....behind enemy lines
I changed out my tranny fluid yesterday. Got home early from working. Anyhow, all went fine except for the amount I could get back in. The capacity I have been told for the NV5600 is 4.75qts. Now I didn't measure the amount that I drained, it went right into the catch bucket, but I could only get 4qts back in before the oil was dribbling out the filler hole. I didn't pull the PTO cover. Is there more oil in there that can be drained out through the bottom PTO bolt hole?? I am assuming that as long as the fluid is up to the filler hole I fine. The front and rear diffs were right on the money as far as the amount of fluid they took. Just need to do the tranfer case and I'll be set for a while. Gotta pick up a larger hex wrench for that. What size is that by chance, anyone know??? Thanks in advance!!! FWIW, I used Amsoil fluids!!
Old Feb 16, 2006 | 05:39 PM
Jeff in TD's Avatar
When I did mine, I pulled the PTO cover and there was still a fair volume of oil sitting in the bottom of the case. I'm sure you are fine.
Transfer case plug is 10mm hex if I recall correctly. Took just a bit over 2 quarts.
Old Feb 16, 2006 | 08:25 PM
HeadsBikesMopars's Avatar
Thumbs up
Dorkweed, Don't mean to hi-jack this thread but I see you have some Husky floor Mats. Where can I find those and Thanks. Terry.
Old Feb 17, 2006 | 02:19 AM
TexasCTD's Avatar
http://www.genosgarage.com/CoastalDa...ID=159&CATID=1
And yes, you did hijack his thread....
Old Feb 17, 2006 | 04:49 AM
bulabula's Avatar
Dorkweed, my tranny took between 4 and 4.5 quarts each time I changed it but there was some variability in the amount I had left over when I was finished. The truck was in the same place each time I changed it out. I stop filling it when it dribble out of the hole.
I used a 3/8" hex to remove the plugs in the transfer case.
Old Feb 19, 2006 | 11:36 PM
Nevada's Avatar
Pull the PTO cover on the drivers side. There is a magnet in the bottom of the tranny that can be accessed through the PTO cover. You can remove it, clean then replace it. Reach in and feel around it is about 1" square and about as thick as a nickel.
Old Feb 20, 2006 | 08:12 AM
Jeff in TD's Avatar
Yeah, I was surprised at how much metal was on mine and I put a photo in my gallery.
Old Feb 20, 2006 | 08:42 AM
MikeyB's Avatar
Just curious here, has anyone removed the top PTO cover bolt and added the other 1/2 quart and round it off to 5 quarts total?
MikeyB
Old Feb 20, 2006 | 05:07 PM
ftltmp's Avatar
MikeyB
When I put my short shifter in I put a whole quart of lucas in it.
esde
Nov 1, 2010 05:12 PM
Dean Snow
Feb 1, 2008 08:07 PM
KC
Oct 24, 2003 06:13 AM
KC
Jun 23, 2003 07:28 PM
