lower ball joint greese fittings
When replacing the sealed lower ball joints on a 2006 with replacement greesable joints, will the axle shafts clear the greese fittings? They look very close.
No they wont. I even got a 90 grease fitting and it was still hitting the u-joint. I greased the ball joint and then removed the zerk and installed the plug that came with it. You can grease in the future, but it's not easy getting the plug and grease fitting swapped out.
jlipskoc
03-20-2011 12:24 PM
wcbcruzer
22
04-30-2008 06:58 PM
