lower ball joint wont tighten
Old Mar 11, 2007 | 01:46 PM
96grndodge's Avatar
I need a little help. I had to replace my upper ball joint on right side, my problem is i am putting the knuckle back on and the nut that tightens up the lower ball joint will not tighten up. The whole stud is turning. What is the deal I am at a standstill, any help would be appreciated.
Old Mar 11, 2007 | 01:56 PM
TIMMY22's Avatar
how far is the nut on before it spins? do you have threads showing on the other side of the nut?
Old Mar 11, 2007 | 02:01 PM
96grndodge's Avatar
it will get about even with the top of the stud i might get a couple of threads to show before the stud starts turning.
Old Mar 11, 2007 | 02:09 PM
TIMMY22's Avatar
if I remeber correctly the lower does not show much thread when it's fully tightend.
Um, try a bottle jack under the ball joint just to one side of the grease fitting. put a little pressure on it then try it.
Old Mar 11, 2007 | 02:11 PM
TIMMY22's Avatar
I know money can be tight but I always do those as a pair. once you replace one, the other is not far behind. a lot of labor just to get at it!
Old Mar 11, 2007 | 02:18 PM
96grndodge's Avatar
Yeah I just want to try to get it going for now, plus i had to have someone help me do it, because i have never done anything like that before, but i can replace them myself now that i know how. By the way that did the trick i got it tightened up. I appreciate the help so much, i need all the help i can get. Thanks again!!!!!!!!!!!!!
Old Mar 11, 2007 | 02:24 PM
TIMMY22's Avatar
anytime...
Hopper
13
Jul 4, 2008 06:20 PM
jimk403
May 9, 2008 04:27 PM
wcbcruzer
22
Apr 30, 2008 06:58 PM
Diesel diehard
Feb 23, 2004 05:05 PM
stoneman
Feb 10, 2004 05:54 AM
