Loud chirping sound at shutdown
My truck has always made a loud chirping sound at shutdown.The sound originates from the serp beltdrive.I have heard other trucks make this same sound and I was told by someone that there is a recall/tsb to correct it.
On a possibly related note just recently I have began hearing and visibly observing a chattering when the a/c is on. The chattering stops when the rpms come up. Tensioner? The compressor is only 4 months old.
Do a search here and on Geno's garage for belt squeal / chirp. The TSB is for the overrunning alternator pulley. I went through 4 belts in 22k miles until I had the TSB done to mine. I no longer have the Cummins Chirp at shutdown
With the high millage you have you need to check the idler pulley and all components for wear, Put a breaker bar on the idler arm to release the tension and slide the belt off so you can check everything out..
Hope this helps
Hope this helps
After 06 model year they installed one way brgs on the alternator pulley to eliminate the belt chirp at shutdown.
The tensioner pulley has also been known to go bad before and make noise, but that would happen all the time while it is running.
sdaly
May 6, 2011 04:27 PM
Euronymous
24
Dec 13, 2007 11:41 PM
craneage2001
Nov 13, 2007 08:56 PM
CobraCTD
Jun 19, 2007 06:09 PM
