Squeal coming from rear end wheels????
Hey all,
I have just noticed a squeal coming from my rear end at the wheels. It is on both sides. I hear it when i start rolling and slowing down. It doesn't get louder with more speed. Could this be my U-Joints? Any other ideas??
Thanks all,
Eric
Thanks all,
Eric
Update. I found the squeak, i believe it's coming from around the carrier bearing area... It squeaks in one spot as the drive shaft turns. Any new ideas???
Thanks all,
Eric
Thanks all,
Eric
I did both of mine myself a couple of months ago (one was squeaking, needle bearings ground to dust), $35/ea IIRC for grease-able, lifetime warranty from Napa autoparts.
Not too bad a job but you'll need a big press to get them out of the yokes.
Thanks a lot, i'll take a look at napa. I'm def going with grease-able joints. Does anyone else have any preferences on which brand and wheres a good place to get them?? If anyone has links that would be awesome.
In case you cant tell im illiterate on this stuff!! lol. But i sure as heck am not paying the dealer 350.00 to replace 2 of them!!!
Well new update. I jacked the rear end of my truck up and got a better listen. Its definitely coming from the rear u-joint where its going into the rear end and not from around the carrier bearing. I just hope its still the u joint and not in the pumpkin
Don't cheap out and don't worry about getting greasable ones, those are the cheapies most of the time anyway. Get a set of Spicer u-joints pressed in and be done with it. The zerk fitting holes make them weaker that is why quality ones will not have them.
