looking for a fuel pressure gauge for monitering lift pump
Old May 26, 2007 | 01:48 PM
bigfish33's Avatar
Question looking for a fuel pressure gauge for monitering lift pump
i have a 2003 & would like to put in a fuel pressure gauge to moniter the lift pump.i know it is suppose to run in the 4-8psi range is the 15psi gauge enough or should i run the 30psi.i like the autometer stuff but cant find a 30psi in the autometer.
Old May 26, 2007 | 02:21 PM
Redline Ram's Avatar
you should get the 30psi because if you ever do upgrade your pump then you will have to get another gauge unless you want to see it maxed out.
Old May 27, 2007 | 01:31 PM
gus's 03's Avatar
i was looking in the factory svc man last night. i was amazed when i saw factory spec was 11.5psi..... i dont think i remember any one posting that hi stk.
as far as the gage, i agree, if plans are to add a aftermarket l/p go with the 30, if plans are to stay stock 15.
Old May 27, 2007 | 01:55 PM
bigfish33's Avatar
are the machanical gauges a must for this or can you go with a electric gauge
Old May 28, 2007 | 08:59 AM
Hooligan6's Avatar
Thanks guys this answers a question I had on my thread : )
Old May 28, 2007 | 09:02 AM
Luvnacumns's Avatar
I have the autometer electric 100! It's overkill but with my fuel system I can crank it up to 40 psi! So 30's not enough..
Shane
Old May 29, 2007 | 04:27 PM
xxwildbillxx's Avatar
Me too, me too...
Wanna install a fuel pressure gauge as well...
How involved/time consuming is a fuel press. gauge install???
lpccbis
Sep 26, 2012 09:44 AM
92smokin blacky
Nov 13, 2010 04:44 PM
chris4122374
Dec 16, 2007 05:55 AM
03sled
Feb 11, 2007 12:21 PM
SSminnow
41
Nov 9, 2006 10:40 PM
