A Llittle Help reading this information please
Old Nov 23, 2011 | 04:36 PM
sisusuomi's Avatar
OK I got a print out from Dodge on our truck it goes as follows:
DJQS 5,200# Front Axle Anything special about this front axle? I see in the lube sheet recomendations from Dodge they list three front axles gear lube (C205FD, 9-1/4AA, 9-1/4 EL which one do I have?)
DMES 3.73 Rear Axle Ratio
DRQP 11.50 Rear Axle DSA Anti-Spin Differential Rear Axle
Does this description for my rear axle tell me if it is Trac-Loc or Trac-Rite /Trac-Rite EL differential? Reason for asking is I need to know what fluid to put into the differentials this spring when I replace the old. I see on the print out to make sure that Limited Slip Additive is added if you have a Trac-Lok axle.
ETH 5.9L I6 HO Cummins TD Engine This one tells me the engine is highout put, but are not all the diesel engines high output?
NHBP Auxiliary Transmission Oil Cooler This means I have an additional transmission cooler correct?
DG8 4-Spd. Automatic 48RE Transmission DHAP Lock-Up Torque Converter Anything special to know about this?
I feel stupid but better to ask questions than go around ignorant.
Old Nov 23, 2011 | 06:48 PM
papaduck's Avatar
The axels are made by American Axel. The rear is a limited slip. Both require a GL-5 75w-90 synthetic. Lots of brands available. No additive is required.
The engine is the High Output, 305 horsepower and 625 ft lb of torque, if I remember correctly. The SO engine has less torque and horse power normally sold in CA.
The auto transmission is the 48RE and is the only auto that was available in '06. It is a 4 speed transmission with a torque converter that will automatically lock up. It is equipped with a aux cooler to help cool it under heavy loads. It uses ATF+4 trans oil.
The transfer case and the power steering also use ATF+4.
Old Nov 23, 2011 | 08:32 PM
rdr140's Avatar
the ho cummins is 305 hp 555tq the .05's had the 325hp 600tq jest saying
Old Nov 23, 2011 | 08:52 PM
ChrisJohnson's Avatar
HO Cummins '03 and '04 had 305 h.p. and 555 ft. lbs. of torque. Your signature says an '06. If you have an '06, you have 325 h.p. and 610 ft. lbs. of torque.
Old Nov 23, 2011 | 11:20 PM
rdr140's Avatar
thanks cris i did not even look at his sig
Old Nov 24, 2011 | 04:27 AM
papaduck's Avatar
Thanx guys for correcting my numbers on the engines. I thought that I might have the numbers mixed up.
mullishacrew
Mar 18, 2012 12:41 PM
CowboyDave
15
Feb 3, 2010 07:35 PM
singledad
Dec 15, 2009 11:50 PM
West Coast
33
Nov 10, 2007 11:26 PM
bigthumper
Aug 8, 2004 08:21 AM
