Lift Pump Replacement 2006
Old Oct 24, 2012 | 01:33 PM
jimbeaux_48's Avatar
2006 ram 3500 new to me. 3rd owner. I am having cooling system issues but am about to flush radiatir wind see what happens. I have no way to find out what has or has not been replaced on this truck. What should I look for to see if the lift pump has been changed?
Old Oct 24, 2012 | 06:10 PM
GreyTD's Avatar
With the truck running do you hear the pump running in the fuel tank? if yes then not changed. Check along the frame rails to see if there is a fuel system added, should be easy to spot. Under the hood drivers side look for blue 1/2" colored fuel lines going directly to cp3, if not there, no upgrade. Do you have gauges? Fuel pressure at idle 10psi or less = oem pump, over 10 closer to 15 or above = aftermarket pump.
Hope that helps a little.
mstep3
23
Jul 27, 2010 02:22 PM
jmccart
14
Sep 17, 2007 08:23 PM
jrussell
17
Sep 17, 2007 06:38 PM
DanTana
Mar 6, 2006 05:56 AM
