Lift pump leaking
Old Dec 28, 2012 | 03:20 PM
INsIdious's Avatar
Lift pump leaking
I swapped out my canister mounted lift pump and now it is spraying fuel between it and the canister, I did not see an o ring or gasket when i took old one off. should there be one?
Old Dec 28, 2012 | 03:49 PM
Dr.Dizzle's Avatar
Yes! There is a black o-ring that creates a seal. You may find the old one in the canister inlet / orifice or the old pump. However, a new pump typically comes with a new one, unless you are replacing it with an old pump.
Old Dec 28, 2012 | 04:01 PM
INsIdious's Avatar
Thanks, i was putting an old lift pump on i got from a friend. I looked on floor and on frame for old one to no avail. i will pull the pump back off and see if it is in there anywhere.
Txwelder
Nov 26, 2025 01:53 AM
Txwelder
May 19, 2005 06:10 PM
uncleroty
Aug 16, 2004 10:49 AM
yrusoslow2
Jul 1, 2003 02:18 PM
christinyou
Mar 14, 2003 03:43 PM
