Lift pump going bad?
Old May 27, 2008 | 03:27 PM
dodchall70's Avatar
I went to start my truck the other day and when I turned the ignition on to let the grid heater cycle the lift pump was really noisey. It was pretty cool outside (about 25 degrees) but it has never made that much noise before. This morning when I came to work, it sounded normal. Do you think this is a sign of the lift pump on its way out?
Thanks for your help.
Larry
Old May 27, 2008 | 09:06 PM
87BRGN's Avatar
Its possible. Is yours on the filter housing or in the tank? Strangely enough mine got quieter before it went out. check for codes.
Old May 28, 2008 | 09:20 AM
dodchall70's Avatar
Mine is still on the filter housing. My truck has approx. 41000 miles.
Old May 28, 2008 | 10:58 AM
lamadera's Avatar
If you can hear it, that's good. Sometimes I hear mine on startup, sometimes I don't. If you want to stay stock, buy a spare from Geno's for peace of mind. Easy to swap out.
Old May 28, 2008 | 12:11 PM
Sasqoutch's Avatar
I'd say look into a pressure gauge, that will tell you real quick if its getting worn out and not pumping like it should
Old May 28, 2008 | 02:10 PM
dodchall70's Avatar
Thanks for the ideas. I do need to get a pressure gauge. I also thought of getting a new pump from Geno's. Maybe I should do both?
rjweiss
16
Nov 25, 2016 05:56 PM
Capp35
Sep 15, 2011 01:21 PM
fastlane
Oct 5, 2010 04:28 PM
MARKY MARK
Sep 15, 2004 08:21 PM
gofastman
Aug 14, 2003 04:24 PM
