lift pump is bad help!!!!!!!!!!!!!
Old Feb 6, 2008 | 10:19 PM
crittergetter's Avatar
i was driving home tonight and truck just dies. i took the filter out and bumped the starter and it didn't pump at all. so at 56000 miles my lift pump and water pump are out. so what would you do??????? put a fass are go back with a warranty pump. my friend ended up putting three warranty pumps on before he put a fass. now he has no trouble. what do i do!!!!!!!!!!!!!!!!!!!
Old Feb 6, 2008 | 10:49 PM
Raspy's Avatar
There is a huge number of posts on this subject. Do a search and decide which pump is best for you.
The lift pump is a known weakness but what do you mean the water pump is out too?
Bumping the starter does not make the pump run. It runs when the key is on.
John
Old Feb 6, 2008 | 11:40 PM
bekim's Avatar
It runs for almost 30 seconds if you bump the starter on mine. Take the free warranty replacement unit in-tank like I did.
Mike
Old Feb 7, 2008 | 01:11 AM
icrider's Avatar
I don't think you're meaning water pump...do you mean the water/fuel seperator that is part of the fuel filtration system, which is right by the lift pump?
anyways, you are correct that bumping the started should temporarily engage the lift pump.
I took the dealer's warranty in-tank lift pump and it's still working for me. If you're running a programmer, go with an aftermarket pump.
Old Feb 7, 2008 | 02:32 AM
annabelle's Avatar
I would have them replace it under warranty. You already have the intank version, don't you?
Old Feb 7, 2008 | 04:29 AM
TexasCTD's Avatar
Intank version didn't start until 05 unless his truck had already been retrofitted at the dealer. 03-04.5 trucks have it mounted on back of the fuel filter housing.
Old Feb 7, 2008 | 04:32 AM
TexasCTD's Avatar
Critter, if you are going to stick with your current power mods....the retrofit intank pumps are holding up very well.
If you plan more power mods....you may want to go ahead with an aftermarket pump....FASS or GDP Walbro etc.
Old Feb 7, 2008 | 07:26 AM
Hounddog's Avatar
Unless doing mods to run the rail dry the factory in tank unit has given very little trouble.Its also designed not to stall you if it fails.Working on getting mine done,just haven't yet.
Old Feb 7, 2008 | 08:19 AM
no i mean water pump THE dam water pump is leaking as well it just started leaking two days ago
so the lift pump is not in the tank on this truck?????? is it like the one on my 98.5 behind the filter??? i didn't look last night i was way to to think it wasn't in the tank. my friends was in the tank on his 04.5 and he put three on his truck. may be the new one are better????
Old Feb 7, 2008 | 08:32 AM
dezeldog's Avatar
You might wanna call Rich at Glacier Diesel and see what he can do for ya. Great product and he is pretty easy to deal with. No affiliation!!!
Jim
Old Feb 11, 2008 | 07:00 AM
Toto's Avatar
I had the intank replacement done on my 04 305 555 about a year ago.
Waranty...no probs since.
Old Feb 11, 2008 | 01:09 PM
C Schomer's Avatar
I used the GDP Walbro. It's cheaper and they are about $115 from Summit if it ever goes again. Craig
Old Feb 11, 2008 | 07:58 PM
rvluversnc93's Avatar
I tyhink the water and lift pump would fall under the engine warranty. I would talk to the dodge service department and see. They did the intank pump on mine and it has worked great.
65fury
25
Apr 6, 2007 08:16 AM
Buckshotram
Jan 9, 2006 09:27 AM
loveturbowine
Jul 26, 2005 05:50 PM
C Pierce
Mar 21, 2005 08:41 AM
niekrewb
Feb 3, 2005 04:17 AM
