knock in engine
Old Jan 14, 2004 | 07:35 PM
mikal711's Avatar
knock in engine
my 04 / 3500 / 4x4/ auto / has developed a knock in the engine the other day its kinda loud . the truck has 12500 miles on it has anyone else noticed there trucks have done the same thing?
Old Jan 14, 2004 | 07:52 PM
spots's Avatar
Fuel. Do a search. Or buy a catchers mitt.
Old Jan 14, 2004 | 08:18 PM
CoastalDav's Avatar
Like he said Fuel, fuel knock. Injector might be over fueling or computer is bugged.
Dave
Old Jan 15, 2004 | 12:45 AM
Vaughn MacKenzie's Avatar
Try some good quality diesel additive like Stanadyne. Use Power Service if you can't find anything else, it's better than nothing. Give it a try.
Also make sure you don't have a Fram oil filter on there
Good luck
Vaughn
Old Jan 15, 2004 | 12:05 PM
mikal711's Avatar
could it be bad fuel . would that cause a knock?
Old Jan 15, 2004 | 02:47 PM
YES
Old Feb 15, 2004 | 11:02 PM
cummins24v's Avatar
FIRST DOES IT DO IT ALL THE TIME, OR JUST AT IDLE. IF AT IDLE #5 CYLINDER IS INSTALLED 180 DEGRESS BACKWARDS AND IS HITTING A OIL COLLING NOZZLE JET THATS THE PROBLEM WITH MINE. GOOD LUCK..
Old Feb 16, 2004 | 08:40 AM
spots's Avatar
cummins24v when you type in caps it is like yelling. Please stop yelling. Thank you.
Do you know how many (if any) of these pistons were assembled incorrectly??
Old Feb 16, 2004 | 10:32 AM
sawboywv1's Avatar
I'm sorry I don't believe the post by "cummins24v"! If that was the case the piston would smack that jet and it would never make any noise again! Also Cummins would not make a mistake of that nature... if they did there would be a TSB!
Old Feb 16, 2004 | 10:55 AM
bulabula's Avatar
Is DC paying to fix it under warranty?
I've gotta believe you made sure you hid all the pulling trophy's, window stickers and restored the engine compartment as best you could after pulling out all the aftermarket power adders?
If not, it may help to leave a Lawrence Welk CD laying on the seat when the service manager looks at it.
And for the orig poster, yeah I'd try some different fuel and/or add some fuel treatment before doing anything else.
Old Feb 16, 2004 | 05:23 PM
mikal711's Avatar
yep it was fuel boys.. drained the tank and new filter and then i quitened down after a tank of fuel.
Old Feb 16, 2004 | 06:42 PM
spots's Avatar
You don't know how true this is. One of the first things I would do is turn the radio on and see what the people listened to. You could almost tell by that how much $$ they had and how hard they were on the vehicle.
Old Feb 17, 2004 | 02:11 AM
Glad you're quiete down there Mikal!
Sawboy there have been several cases of reversed pistons on the HO motors (SOs are not affected due to not having gallery cooling, only piston spray).
The jets do not get broken off, the piston just taps them, doesn't really do damage but not good for it either. A couple of guys have gotten new short blocks under warranty, no labor charge.
Vaughn
Old Feb 17, 2004 | 05:49 AM
NDanecker's Avatar
Nothing better then judging a book by its cover!
Old Feb 17, 2004 | 10:33 AM
spots's Avatar
Vaughn
Vaughn MacKenzie do you know the affected vins for these reversed pistons?
