Just some info (long post)
Old Feb 11, 2009 | 10:00 AM
aketay's Avatar
Just bought an 03' QC LB 2wd with 154K miles in January. Paid $11,000 for it, thought that was a good start. Initially the truck was in pretty rough shape. CarFax said it was a two owner truck. Truck appeared to be a typical Oklahoma farm/ranch truck, even has a miniature cast set of Longhorns on the top of the grill. Engine started fine, but was very loud and ran rough when compared to my last two Duramaxes. Transmission shifted hard, but was firm and quiet when warm. All of the major suspension parts seemed to be in good shape. Interior was fine, a little dirtier than normal including all of the fly sheet on the roof liner, but could be cleaned up in time. Only thing missing was the ashtray leaving a hole in the dash. So I took her home to see what I could do for her. First 460 miles driving home revealed some other small problems, drive line vibration, bad tires, bad brakes and rotten door seals. Still encouraged with this project. After reading all about the maintenance requirements and suggestions, I decided to treat this like it only had the oil changed when the idiot light came on.
First off was to change all of the fluids. The engine oil was dark, thin and overfilled by about 2 quarts. Smell test indicated it was not diesel in the oil, just old oil. The transmission oil was also dark and old. Could not feel any oil thru the fill plug before draining and it only dumped about 3 quarts. The rear end only dumped about 3.5 quarts after tilting side to side. In with the new, prefilled oil filter and ended up putting 12 quarts of Valvoline 15W-40 to reach the middle of the hash marks on the dipstick. Still in the same spot almost 4000 miles later and still light brown. Filled the tranny and rear end with a gallon of ATF each and drove it around for 20+ mile to clean. Redrained for about 3 hours and used a rag to soak up any residual oil. Refilled the trans with Pennzoil Synchromesh, 5.5 quarts. Trans shifts real nice now. The rear end got 5 quarts of MOBIL-1 75W-90. Pumped out the power steering fluid twice and refillled with ATF+4, quieted the rack at idle. Also replaced the brake fluid in the clutch and brake master cylinders. At this point the truck is starting to feel refreshed and smooth.
Next was new rubber and pads. Firestone Transforce HT's were on sale, $109 a tire, $638 total for the works. Typical brake job with semi-metallic pads from NAPA, turned rotors for $215 total. Again, quieter ride and better than new braking.
At this point, less than $1000 spent, the truck feels better. Time to concentrate on the engine and quell the fear of a bad injector causing the rough idle. Assuming that the valve lash had not been checked at 150K I started there. Surprised me, they were all in spec. Changed the air filter, filter minder showed it was good but the filter was creased like it had been sucked in. Now for the best part because it was virtually free. Using CRC Electrical Contact Cleaner and CRC Contact Lube, I cleaned the MAP and IAT sensors. Idle was getting better so I cleaned and lubed every connector I could find under the hood. This was the most amazing transformation, it idles quiet and smooth now. It will also run to 3200 rpm under load.
This runs good enough now that I'm confident to take her out for the first load. Go to Denver, pick up Merritt stock trailer and deliver it to St. Louis. All is great on the way to Denver, small vibration @ 70-75 mph. Not worried because I read about the drone. Hook up the trailer and start to pull forward slowly and it hits me hard. Small vibration is now a loud knock. Drive faster and it goes away mostly. Its getting to be evening rush hour so I try to get out of town. Gamble that I can make it back to Limon and have it looked at. Called the dealer and prepped them that I'm limping there. Arrive at 5pm, they take the driveshaft off and confirm that middle u-joint is siezed. Replaced middle and rear for $291 with the factory sealed units. On the road again by 6pm, thank-you Limon Dodge! Now it run real good. Deliver in St. Louis by noon. Fresh money in pocket ready for the next load.
This was worth the effort, basically a new truck for less than $13,000. Will keep you posted as it goes.
Anthony
Old Feb 11, 2009 | 10:10 AM
nkennedy's Avatar
I believe you have one of the best that Dodge/Cummins ever made. The 03 to 04.5 years are great trucks, and get great milage.
Old Feb 11, 2009 | 10:21 AM
aketay's Avatar
Thanks, I pretty much narrowed my search for one of these trucks for those reasons.
Just a side note to my first post, I manually bent the top of the doors to decrease the wind noise. Seems to work.
Next I have to find coil springs for the front as the passenger side is sagging about ¾ of an inch.
Old Feb 11, 2009 | 11:01 AM
dozer12216's Avatar
Great!!! You never got negative about the consequnces of buying a used truck, but started working out the details. Even when you had a unexpected issue, you made friends and got resolved.
Old Feb 11, 2009 | 04:09 PM
Sasqoutch's Avatar
Congrats on the new purchase! I love my 03 and am up to 132k miles, just keep an eye on that stock lift pump. Mine was done at 100k miles
Old Feb 11, 2009 | 05:36 PM
billie's Avatar
The door seal leak is due (motly) to the top door lip extending above the roofline. They changed it in 05. My only beef about my truck.
How did you bend your door? Just brute force and ignorance, or did you use a trick to not damage the interior trim? I can't seem to get enough pressure without risk of damage.
Well done in doing the basics and reviving (saving?) a great truck. There's a lesson in this for many truck owners.
Cya
Old Feb 11, 2009 | 10:15 PM
aketay's Avatar
Brute force, sit in the seat with bare feet at the lower window level and use hands to pull in the top. Helps to be over six feet tall. You can also use a short 2X4 in the door jamb and push in at the top of the door
ilmbg
Nov 6, 2016 03:57 PM
pulltilbroke
Jul 7, 2011 10:19 PM
dieselJon
Apr 10, 2007 10:55 PM
cquestad
Aug 9, 2005 04:10 PM
Homestead
Jan 18, 2005 09:44 PM
