Jake Brake Light
Old Feb 23, 2007 | 08:11 AM
dws35's Avatar
Jake Brake Light
I wanted to confirm that the Cummins/Mopar jake brake is supposed to have a small LED light come on when the jake brake in turned on. Mine has never had a light come on since it was installed. I thought I read somewhere that the instructions were wrong (wires were mis-labeled) and this error caused the light not to work.
Any insight to this issue?
THanks
Old Feb 23, 2007 | 08:26 AM
TonyB's Avatar
The LED you ask about is right next to the pull switch for the jake.
As far as polarity, yes the LED will no work if wired backwards...I have not heard of wiring problems.
I'd take it to the dealer & let them sort it out.
Tony
Old Feb 23, 2007 | 08:46 AM
ColdCase's Avatar
The light is suppose to come on when the switch is on.
Old Feb 23, 2007 | 09:01 AM
dws35's Avatar
Thanks for the quick and helpful feedback. Any suggestions on what 2 wires are likely to be reversed for this light not to work?
FYI - The brake itself works correctly, it is only the light with a problem.
Thanks again
Old Feb 24, 2007 | 03:30 PM
rustyshakelford's Avatar
when mine was installed, i watched and saw that he forgot the black wire...it didnt mention it at all in myinstructions. so he went back and figured it out. i think its yellow to yellow/black. i dont know if that has anything to do with it, but id make sure that all four wires are accounted for
brett
Old Feb 24, 2007 | 08:23 PM
Jeff in TD's Avatar
Go here
http://www.jakebrake.com/support/
and select the 5.9 ISB Dodge, the download the installation manual...
If I recall correctly there were three wires from the switch... Red went to keyed power source, yellow went to position 39 in the connector B on the computer, and grn/yel went to ground...
Old Feb 25, 2007 | 09:03 AM
Originally Posted by Jeff in TD
Go here
mine was done thursday, but i know there was a black, yellow, red and i think green. im almost positive theres 4 wires total coming from the switch. ill go look in a bit and post if im wrong
brett
Old Feb 25, 2007 | 09:36 AM
carharttfarmer's Avatar
there is one wire from the switch that isnt mentioned in the install manual but it is in the wiring diagram
Old Feb 25, 2007 | 08:45 PM
Jeff in TD's Avatar
OK, I see what you mean in the diagram.
It shows a red and a black wire coming from the switch, that get spliced to a yellow wire that leads to ground. The red wire from the switch ends up hooked to the gray wire which leads to keyed power. Then the Yellow wire goes to 39B...
It was a while ago since I installed mine...
Joey-D
Dec 12, 2011 12:52 PM
polaris800sp
Apr 7, 2009 10:08 AM
dws35
Sep 6, 2006 06:27 PM
wvcowhauler
13
Apr 3, 2005 11:39 PM
