Issues
Old Jul 13, 2017 | 04:44 PM
Aaron Rudd's Avatar
Issues
Thanks for reading and your help!
I have a 2005 Ram 2500 5.9 cummins Automatic tranny. Within the last week, I started having some issues. When I come to a complete stop while in drive, the truck tries to pull away. There is also a bit of black exhaust when this is going on. If I hold the brake and shift to neutral, the rpms shoot up to around 2000-2500 then back to idle. I thought it was a tranny issue so I took it to a tranny shop here in Alaska and they told me it was an injector pump issue. Has anyone had this same problem before? Any ideas? Thank you
Old Jul 13, 2017 | 05:39 PM
johnh's Avatar
lock up converter
Old Jul 13, 2017 | 05:43 PM
Aaron Rudd's Avatar
Not quite sure what this means.....
Old Jul 14, 2017 | 10:18 AM
FMB's Avatar
FMB
He is saying your Torque Converter is locking up. Find a different tranny shop.
Just back from another Alaska trip. Back to morning brew . . .
Old Jul 16, 2017 | 10:27 AM
Mike67RS's Avatar
Your torque converter is designed to keep the truck from moving forward up to a certain RPM. Stock is around 1800 RPM. If you're at idle and your engine speed is over 1800-1900 RPM, your truck is gonna creep forward. I think this is what you're feeling. If your idle is high in park or in neutral (as you said it was), you have a problem with your engine that is causing the high RPMs. Your tranny guy may be on the right track.
Old Jul 17, 2017 | 05:50 AM
saggonwaggon91's Avatar
Still sounds like a torque converter issue. The engines torque managment is trying to keep it from stalling out and when you shift to nuetral, it takes a second to come back to normal idle.
Old Jul 17, 2017 | 09:05 PM
BigIron70's Avatar
Cummins Guru
Correct
pappyman
Dec 11, 2002 03:37 PM
crossy
Dec 8, 2002 05:14 PM
crossy
Dec 5, 2002 10:42 AM
TXTad
Nov 11, 2002 12:39 PM
