Intermittent clicking from motor area?
Old Apr 19, 2005 | 05:43 PM
Cummins600's Avatar
Question Intermittent clicking from motor area?
Recently I've noticed new clicking sounds from the motor area when warm/hot. The clicking seems to come from the drive belts and pulleys while idling. After shutting down the motor to inspect and then restarting it again the clicking sounds went away. So, the clicking comes and goes. Any ideas to the cause or source of this clicking sound?
Old Apr 19, 2005 | 06:31 PM
Mark Thomas's Avatar
Clicky injector maybe
Old Apr 19, 2005 | 08:41 PM
Graphite600's Avatar
It's your A/C compressor engaging and disengaging.
Old Apr 19, 2005 | 09:18 PM
handymantim's Avatar
I was going to guess the A/C compressor too.
Old Apr 19, 2005 | 10:03 PM
Hemi Cat's Avatar
You may have a pulley bearing getting dry and ready to fail. Remove the belt and spin each pulley to listen for noise and feel for rough bearings. Also check your belt for glazing and cracking. If antifreeze spills on the belt, it will make a chattering noise for a while.
Old Apr 19, 2005 | 10:48 PM
Cummins600's Avatar
It's not the A/C compressor, but the sound was about the same and as load. The clicks would sound about every half a second at idle (click, click, click, click).
I've done a few shorts trips since and all is good at this time (for now). Maybe it could be a forward injector making the racket.
Old Apr 26, 2005 | 10:51 PM
Cummins600's Avatar
Strange! Whatever it was it is gone. Haven't heard it for days now.
Old Apr 27, 2005 | 05:42 AM
nickleinonen's Avatar
still might be the a/c clutch... the a/c system cycles when the heater mode is selected to defrost, even with full heat on the temp control selected
Old Apr 27, 2005 | 07:15 AM
bluebull's Avatar
I don't know about the 04.5's but on the 05's the air does not run on any of the settings unless you push the air conditioner button to turn it on.
Old Apr 27, 2005 | 06:21 PM
underwoodtransp's Avatar
wrong!! My 05 runs the compressor on defrost. I just turn it over to the vent selection and the "surging" goes away.
Old Apr 27, 2005 | 08:09 PM
Cummins600's Avatar
Nope, I know better than that. It was something else.
Old Apr 27, 2005 | 08:33 PM
supercharger's Avatar
I have the clicking noise too and yet to figure it out. These engines have so many noises and vibrations I don't worry about nothing anymore, if it locks up so be it. It is almost impossible to find the source of the noises, I have and empty cup rattle in the dash and can't find it, the 2000 rpm vibration that vibrates the rear view mirror into a blur, the clicking noise is sporatic and sounds like it is in the front of the engine. My fuel mileage is excellent and I keep my fluids changed and run fuel additive to boot. If it won't make it to 400k I'll try a ford or chevy next time.
Old Apr 28, 2005 | 09:01 PM
Cummins600's Avatar
Must be my drivebelt making the noise. See post: Drivebelt gone bad - replacement and/or warranty
Old Apr 28, 2005 | 09:23 PM
i6DZUL's Avatar
Ya know, I've thought so many times almost exactly what you wrote but never put it on the screen. Thanks for a well written post.
Old Apr 28, 2005 | 09:57 PM
03 ant a hemi's Avatar
go buy a stethescope, listen to each injector and see if it is that. I have #1 injector ticking away at idle and low rpm, yet the dealer says it is all fine, my stethescope tells me different. I have the tick tick every second or so.
JARHEAD
Jan 28, 2012 10:51 AM
smokester
May 27, 2011 05:31 PM
CaledoniaOutlaw
Jan 18, 2009 09:18 PM
NoSparkplugs
Jan 22, 2007 05:30 PM
Dodgezilla
17
Mar 22, 2005 03:45 AM
