Installed indexing ring---Now have a leak!!
Old Apr 1, 2009 | 10:09 PM
sqrl$$'s Avatar
Installed indexing ring, now have a leak, need help.
Installed indexing ring, and now I have a leak. I followed directions about putting a bead of silicone on both sides of the ring. What I don't get is that there was no type of gasket or sealant on the case when I pulled it down and everything was as dry as a bone. Now with silicone I have a leak. I thought the t-case and transmission fluids stayed seperate. Why would I have a leak now.
Old Apr 19, 2009 | 10:40 PM
sqrl$$'s Avatar
Got everything fixed. Appears that Superlift sells the kit incomplete. I had to order the seal spacer from Skyjacker. Got screwed in the process because if I would have ordered the entire kit from Skyjacker to begin with it would have cost me $289, now since Superlift's kit ($269) didn't come with the seal adapter, I had to order it seperate, (another $68). Superlift offered no help and didn't even offer an appology for selling me an incomplete kit. Word of advice to anyone ordering from Superlift, look to make sure they are selling you everything you need with it.
Old Apr 19, 2009 | 10:43 PM
CrashCade's Avatar
Wow, I had/have the same problem, I had to drop my t-case a few times to get enough silicone and it still leaks. Do you have a part number? I have good contacts at Superlift. I can give them a call and see if we can figure anything out.
Old Apr 20, 2009 | 06:36 AM
sqrl$$'s Avatar
Talked with Michael at Superlift when all this happened. He said that I should write in a letter to him to give to "the powers that be" He said I am not the first to complain about this.
My biggest gripe was that it did not even mention needing it in the instructions, or any of the web site. It would be one thing if I would have been told that I might need this seal extension, but nothing mentions it at all. When you order the seal extension, you will need to go to the dealership and get another factory rear output seal because you will ruin the on in it trying to remove it. Luckily they are only about $10
I will try to find the invoice to get the part number
Old Apr 20, 2009 | 06:39 AM
sqrl$$'s Avatar
Not complaining about Michael, he helped tremendously, just dissappointed with Superlift.
Old Apr 21, 2009 | 08:37 PM
sqrl$$'s Avatar
Part # is SKYDTSA10 for the seal spacer.
Old Apr 22, 2009 | 12:59 AM
pullin hard's Avatar
sorry to jump in here, but when is the indexing ring needed?how much lift?
is the skyjacker parts or kit pretty much the same, just with all the parts needed?
Old Apr 22, 2009 | 10:04 AM
beaver76's Avatar
My Pro-Comp lift came with the indexing ring ,and yes it came with the seal spacer too. I checked the dealer and they wanted $30 for that seal i told them to forget it and went to Napa for $13.
Clayo989
Dec 27, 2009 02:03 PM
Bradleysram
Jan 14, 2009 10:44 PM
Willie B
Jul 4, 2008 08:16 AM
lowboy18011
Oct 29, 2007 07:35 AM
SmokenRam
Jan 16, 2006 01:28 PM
