2008 G56 indexing ring
Old Dec 16, 2009 | 02:19 AM
Clayo989's Avatar
what is the best indexing ring to run on a 2008 G56 manual transmission. I had a Rize indexing ring on it and it gave me trouble when using the exhaust brake (my 2007 did the same thing). When exhaust brake engages something grinding and slipping untill clutch is pressed. Took the indexing ring off and all problems fixed, but front driveshaft vibration and 70 is to bad to take. i have a new driveshaft made for high angle but still has vibration. if anyone could recommed a solution, i would be happy to hear it.
thanks for any help
Old Dec 27, 2009 | 02:03 PM
Clayo989's Avatar
what to do
this is getting really aggravating, i reinstalled the indexing ring to see if i could live with not using my exhaust brake, because the 800 dollar front drive shaft had made was still vibrating to bad and was getting worse and worse. Now i dont even have to have the exhaust brake on, just let off the trottle and while slowing down something is slipping out and grinding. I marked the output shaft on tranny and the input shaft on the transfer case and it still has about 1 1/2 overlap after the 3/4 indexing ring so i dont think it slipping apart there. is there any reason the transfer case would be slipping internally because of the new down hill angle? This is a NP273D transfer case not the older NP241D. I have called all the lift kit providers and no one have a clue of what i am talking about, i guess no one has put a indexing ring on a 07 or newer dodge with a G56 and a NP273d electric shift transfer case, because my 07 and 09 both did the same thing. I want to buy whatever it takes to fix the problem but i dont know what to buy.
sqrl$$
Apr 22, 2009 10:04 AM
Bradleysram
Jan 14, 2009 10:44 PM
Willie B
Jul 4, 2008 08:16 AM
lowboy18011
Oct 29, 2007 07:35 AM
SmokenRam
Jan 16, 2006 01:28 PM
