injector ohmage
Old Nov 23, 2015 | 11:26 PM
pw58's Avatar
injector ohmage
My truck has been missing on a couple of cyls as of late. I get p0204 ,p2149 ,and p0483.I checked the resistance of the injectors. Five had 1.8 and number 6 has 2.5 ohms. The truck starts great but misses. Is this a solenoid issue .
Old Nov 24, 2015 | 03:11 AM
Steve-l's Avatar
Checking the resistance of the actuator coil is not sufficient to determine the health of the injector. They must be removed from the engine and tested on a test bench.
Old Nov 24, 2015 | 05:45 PM
steelblitzkrieg's Avatar
DTR Detective
2.5 is out of spec, you want below 2 ohms.
Old Nov 24, 2015 | 06:51 PM
pw58's Avatar
I had the injectors bench tested last year, 3 were bad so I replaced those. (poor starting truck with lots of smoke) Now it is intermittent, so I seems electrical, of course #6 is 2.5 ohms. The truck starts very well, so I think there is no heavy bleed back on injectors
Old Nov 25, 2015 | 09:05 AM
PWong's Avatar
P2149 BANK 2 (CYLINDERS 4-6) SHORTED HIGH OR LOW - Mopar1973Man's Dodge Cummins Articles
P0204 INJECTOR #4 CONTROL CIRCUIT - Mopar1973Man's Dodge Cummins Articles
Both codes point to #4 cylinder.
It's the #4 injector solenoid or the wirings from ECM to solenoid, high side or low side circuit.
Old Nov 25, 2015 | 09:09 AM
PWong's Avatar
P0483 FAN SPEED - Mopar1973Man's Dodge Cummins Articles
Old Nov 25, 2015 | 09:22 AM
PWong's Avatar
Good solenoid reading should be less than 1 ohm.
Old Nov 26, 2015 | 07:40 AM
pw58's Avatar
I was suspicious of the high ohm readings, it turns out when I fixed the probe along time ago it never really zeroed after that, 1.5 ohms high. I rechecked the upper harness for continuity and shorts, it is ok. I checked the lower harness for shorts, none found. The ecm connectors came apart and got die elec. grease as well as the upper connectors. Long story short, fired up runs like a champ, but we'll see how long that last. thanks everybody
Old Nov 29, 2015 | 12:38 AM
pw58's Avatar
just put 3000 kms on no problems
gablekevin
Sep 19, 2006 12:12 AM
kawi600
Jan 26, 2006 10:19 AM
G-NOTE
Sep 1, 2005 06:36 PM
oscaroc
Apr 2, 2005 12:14 PM
