The idiot and the Transfer case!
Old May 18, 2012 | 06:37 AM
papaduck's Avatar
Some ways to get hold of it come to mind. I have a tool that has 4 small fingers on the end of a flexable wire wound tube. It has a plunger that expands the fingers and when released it could grab the tube and pull it out.
A pair of long needle nose pliers or a surgical forceps might get a hold of it. If it is to the side of the hole maybe a needle nose with a 90* bend in the nose will work.
You might bend a wire into a long U, get it to slip over the tube and work the shorter end back into the drain hole. You would then have both ends of the wire to pull on which would allow a lot of pull pressure to get it out.
Old May 23, 2012 | 10:51 AM
Shorts's Avatar
Did my tranny and tcase yesterday. I giggled a little bit when I went to refill the diff, "Do not use a tube"
R13, how'd you manage to get the tube out? I saw what you were talking about there at the drain hole/pick up tube. It wasn't a clear shot out of there.
Old May 23, 2012 | 12:49 PM
Busboy's Avatar
Take a piece of hardened inner cable from a heater/vent control or lawn mower throttle cable then bend a small 90 deg on the end. It must be small enough to fit inside the tube you used. Fish the cable all the way through the tube and the 90deg will catch the end and you should be able to wiggle it out by pulling gently and guiding the front end of the tube with a small screwdriver. I keep a selection of old vent cables with the original Tee handle and cable cut to various lenghts for these kind of things.
Old May 23, 2012 | 03:17 PM
R13's Avatar
R13
Perfect timing I was coming in here for an update.
Yes...say no to tubes
After getting it to the bottom I used a piece of wire hanger to get it right against the pickup, then using a hook style pick I stabbed it and just fandangled it out the lil gap over the pickup tube.
Old May 23, 2012 | 03:23 PM
R13's Avatar
R13
I already got it, but that's a nice sounding trick. I'll definitely keep this in mind for any future situations that may come up.
Old May 23, 2012 | 04:21 PM
Shorts's Avatar
Great tip busboy.
You know what comes to mind for this? Old clutch and throttle cables from a motorcycle. I have a few of those stashed in my parts box on the shelf. Great to know
Excellent
And I think we should start a "maintenance gone wrong" group
Old May 23, 2012 | 04:22 PM
papaduck's Avatar
Great, I am glad you got it out without taking it apart. I know that your are too. We have all had our dumb mistakes. Again, glad you solved yours..
Old May 23, 2012 | 04:49 PM
R13's Avatar
R13
Excellent
I'm pretty sure that would be a large group...
Thanks...It was a huge relief.
Old May 23, 2012 | 04:51 PM
R13's Avatar
R13
Just wanted to thank everyone who offered up some advise...it was really appreciated.
Old May 23, 2012 | 06:02 PM
rockcrawler304's Avatar
Glad to hear you didn't need to pull the case!!
wyododge
Aug 18, 2011 07:48 AM
SBRW
Jan 11, 2008 07:56 AM
Lightman
16
Jan 21, 2004 10:46 PM
theWizard
Oct 23, 2003 11:53 AM
