Idiot previous owner!!!!!!
Old Jul 26, 2013 | 10:48 PM
03 Melt Down's Avatar
So I had my head in the machine shop to repair a dropped valve seat in my 03 so I told him to just do everything all new as in EVERYTHING. I expected a bill of 600-800 dollars, so this morning I get a call from my machine shop guy who I've known forever with bad news. To make a long story short someone has milled almost 125/1000ths off this head. Its completely junk now so what's my best option moneywise to do here. Anyone have a head for sale?
Old Jul 26, 2013 | 11:16 PM
Rednecktastic's Avatar
Is it not true? Can't be reused?
Old Jul 27, 2013 | 12:15 AM
cdennyb's Avatar
From: In Oroville, Ca., same house for past 46 yrs!
These guys have a new one for $1500... without a core since yours is "junk"
This is complete with valves and has a 2 yr warr.
http://www.ebay.com/itm/NEW-DODGE-RA...ht_1326wt_1163
Old Jul 27, 2013 | 10:53 AM
The head is true its just milled down to much to be used and still have some meat left in the seats. I would like to have that head on eBay but 1500 seems a little out of my price range after already rebuilding the engine and injectors.
Old Jul 27, 2013 | 07:16 PM
sojoe's Avatar
What a bummer!
Sometimes things just suck.
Have you checked with other machine shops/gotta be some alternatives.(?)
There are a lotta really well informed people on here, hopefully some will chime in and help out.
Your compression ratio must really have been really HIGH with that much meat removed from the head. Why would it be cut.125????????---that is ALOT.
Good luck, hope you find a cyl head someplace at a reasonable price, or a repair.
Old Jul 28, 2013 | 06:35 AM
j-fox's Avatar
Milling heads that amount was an old trick with low compression gas motors in the 70's.
I am guessing the PO was an old hot rodder with access to a mill!!
The only real change he made was piston to valve clearance and injector to bowl placement!!!
Old Jul 29, 2013 | 10:28 PM
Yeah it sucks. I found a newer model head with inconel seats with only 90,000 miles the PO spun a bearing from bad oil. I got it for $500 so I'm happy.
Milling the head doesn't really affect the compression on our motors as they have a near flat firing deck. I don't technically think its even called a "cylinder" head in a Commons. But yes my injectors were really in the bowl with the previous head. The main reason I was scared of the previous head was due to the seats being really iffy about taking the high egts with so little meat left in them.
Old Aug 1, 2013 | 09:18 PM
Spooler's Avatar
Good move. The newer heads are better and less likely to drop valve seats.
BearKiller
Jul 13, 2009 01:34 PM
Tree DR
23
Jan 23, 2008 03:51 PM
MmmDieselFumes
Jul 16, 2007 08:10 AM
bigragu
Nov 13, 2006 02:29 PM
Steve10
Feb 20, 2004 09:40 AM
