I need a few opinions on my 03
Old May 3, 2007 | 10:07 PM
dodgepower88's Avatar
1st: The last two times if have changed oil on my truck I think that i fill it right, but i check again a few days later and it is 1/2 over safe. Does it take a while for the oil to get to the pan, or is it playing tricks with me? I fill it with 2.5 gallon jugs, but i take my time and that's why i'm lost. (I've smelled the oil and i can't smell diesel, so I think the injectors are good)
2nd: What are the warning signs of a lift pump going out? Sometimes when i start it up whether it is warm outside or 5 degrees it feels sputtery for the first few minutes ( i changed my fuel filter 5k ago).
3rd: My rear passenger turn signal went out today. Is there something that i should check before i get a new bulb or am i trying to think too much?
Any pointers or ideas will help. Thanks
Old May 3, 2007 | 11:09 PM
labreck's Avatar
1)are you whatting 1/2 hour after you fill oil ?
2)low idle at warmup is normul.
3)your thinking too much, replace it - if it dose go out after that lrt us know
good luck
Old May 3, 2007 | 11:15 PM
DODGER BOMBER's Avatar
oil takes 15 minutes if the motor is warm to go from head to pan. just so u know. 30 min for a fresh oil change is about right. it takes 11.9L of oil in my 03. just a thought. Also, with a bad lift pump, it would run terible, it would barley idle and want to die all of the time. like stated above, its cold, let it warm up.
Old May 4, 2007 | 07:18 AM
SAVOY1964's Avatar
03’s had a problem with the circuit board corroding causing the dash light out to come on. This was fixable under warranty.
Old May 4, 2007 | 10:14 AM
Thanks for the answers. I'm going to go check on the bulb today
Haulin_in_Dixie
Jul 7, 2023 02:13 PM
Iwantadodge
17
Dec 28, 2010 08:54 PM
bansh-eman
15
Sep 21, 2009 11:11 AM
06dodgedrw
Jan 5, 2009 05:17 PM
GoodoleBob
Sep 27, 2006 11:37 PM
