I hate my 3.73's
Old Jan 15, 2012 | 02:51 PM
Adaminak's Avatar
Anyone thought of the feasibility of swapping in a set of Dana axles from an '02? It'd probably be cheaper to buy a set from a junkyard than it would be to buy and install new gears. I'm pretty certain the back would be an easy, direct swap, but the front may present a few more challenges...
Old Jan 15, 2012 | 06:49 PM
Danderson's Avatar
The rpm's on my '07 w/g-56 were brutal even w/285-70-17's. I upped to 285-75-17 Toyo MT's. RPM's are down but mileage was killed do to the mudtread. I may try the Nitto Duras next,but that's going to be awhile as the MT's have 14/32 after 10K.
Old Jan 15, 2012 | 08:22 PM
GLHS's Avatar
For you guys with the early G56, you could swap a G56 from a 6.7 (07.5) and up truck to get a .74 overdrive ratio. The 5.9 G56 is only .79 overdrive.
Final drive with 3.73 and .79 is only 2.94, with 3.73 and .74 is 2.76.
I just sold my 08 g56 tranny.
Old Jan 15, 2012 | 09:28 PM
GLHS's Avatar
Just thought I would add.....My 03 with 3.73 and a 5600 (.73) equates to 2.72 final. With a 3.42 gear set, 2.50 would be my final drive ratio.
Old Jan 16, 2012 | 10:44 PM
snipes999's Avatar
I put the 3,42 gears in my truck with the g56 and with 285's on it turns at 1800 rpm at 65 mph . I am now running Yokohama 315's and at 70 it now runs at 1750 rpm . I like the change and the fuel mileage change it went up about 2 mpg . I pull off and on and have no trouble with it. Got the gears from west coast diff with the mini install kit for under 1000.00 and installed for 600.00 . Well worth the money to me .
Old Jan 17, 2012 | 08:20 AM
jstone44720's Avatar
http://www.justdifferentials.com/ind...acturers_id=43
They have the 3.42 gears and setup kits. I do not know for sure about a spacer being required on the 3.42 front, but it wouldn't surprise me. They also sell a truetrac for the rear end. I am loving mine so far. You can get the electric locker from the front of a power wagon there also. I haven't dealt with them yet, but they are one of the only places I have found selling OEM AAM parts.
Old Jan 22, 2012 | 12:41 AM
DaveB.inVa's Avatar
Not all 5.9 G56's have a .79 OD. Some of the late 2007 5.9's have the .74 OD ratio. Mine was built in Dec 2006 and has the AE G56 with the .74 OD.
Old Jan 22, 2012 | 08:15 AM
prlsnpsdodge's Avatar
Randy's Ring and Pinion has the 3.42's plus the install kit for less then 900. I'm having them put in at the end of the month. Then onto 285/75's. At 65mph, I'm at about 2100. I'm mostly Hwy and back and firth to Huntsville takes forever at that speed.
Old Jan 26, 2012 | 01:42 AM
mtman86's Avatar
Originally Posted by 07_Ram
Anyone actually running this aftermarket gear in their rig?
I used a Yukon Ring and Pinon set-up on my frt Dana 60 axle on my 86 Chevy. I changed to 3.73 from 4.10, and they've held up well......nice pattern when I did the initial set-up. Think I got the kit from Randy's Ring & Pinon. Just clean out the interior of the axle housing real well, so you can start out w/ everything clean. Have a professional do your ring/pinon setup if you haven't done this before. You only want to do this once.
Old Apr 8, 2012 | 12:58 PM
07_Ram's Avatar
my concern with a 48re and 3.42's is the rpm's will be so low the fuel economy will actually worsen
Old Apr 8, 2012 | 01:20 PM
madhat's Avatar
Administrator/Jarhead
I run 295's with my 4.11, and it has a pretty good cruise of 1900 at 72... you may want to look at taller tires. It is the least amount of question marks.
05CTDN8
Jan 23, 2007 09:35 PM
ptgarcia
27
Nov 18, 2006 09:00 PM
TEDHRS
Jan 13, 2003 06:08 PM
Jbolt001
Nov 5, 2002 09:57 AM
Wade
Oct 10, 2002 04:06 PM
