How's overhauled their own truck?
Old Mar 24, 2010 | 09:02 PM
snowmanx's Avatar
Who's overhauled their own truck engine?
Considering as an option, my friend has a shop with all the tools needs to do the job, (minus any specialty tools) both of us are mechanically inclined.
Would you tackle it? A local shop said about 40 hours, so I'm figuring about 100-120 hours for us to get the job done.
Any comments are appreciated.
Thanks again.
Old Mar 24, 2010 | 09:21 PM
SmokeN 12 ValvE's Avatar
I am building my first engine, just ordered the gaskets, bearings, and pistons yesterday. Mines a 12v though and its going back to stock for now.
Old Mar 29, 2010 | 01:45 AM
torquemech's Avatar
Bought mine with 200,000 on odom, at 208,000 three piston rings let go . Overhauled mine , took some time cause no time off from work but you should be able to get her done in about 4-5 days for a first timer.
Old Mar 29, 2010 | 07:41 AM
Load Hauler 04's Avatar
I have done a few of the 12V engines. The problem with late 24V engines is that nobody makes a aftermarket kit for them , so your kinda stuck to buying from Cummins $$$$$ I haven't tryed to buy a kit for 03 and up for about 6 months, someone may have came out with a aftermarket kit. Cummins got me for almost 3000.00 when I did my 04, then machine work after that... Not to bad of a job if you have built engines before and are not in a hurry.
Old Mar 31, 2010 | 01:28 PM
Moose10's Avatar
3G for what??? Bearings, rings, pistons, and seals?
I'm getting ready to do my first rebuild (due to the tappet cover gasket blowing out), but it's NOT going to cost me 3G's...
Old Mar 31, 2010 | 02:07 PM
If you go with Cummins parts , it will be real close. Pistons for a set 875.00 , because the engine was dusted. Gasket set lower 150.00 . Gasket set upper with valve cover, almost 500.00 . Bearings mains,rods,cam 325.00 other misc. parts like hoses, belts, water pump, idler pully brg, brought the cost to almost 3000.00 Then Machine work. 1800.00 Oh, I forgot cam and lifters............The list go's on and on..........
Old Mar 31, 2010 | 03:29 PM
mmurray's Avatar
Here is a 24v 5.9L complete rebuild kit for under $900
http://cgi.ebay.com/ebaymotors/Cummi...item20af6a36ac
Old Mar 31, 2010 | 03:36 PM
That is for a 98.5-02, they do carry some CR gaskets. Enterprise Engine Performance is where I bought the kit for my 12v, it came with Mahle pistons.
Old Mar 31, 2010 | 04:51 PM
Sorry guys, I just posted what it cost me. It would be nice if the kit fit a 03 and up though..........
Old Apr 1, 2010 | 11:09 AM
mmurray's Avatar
Ah... Missed that! But it does say below that...
Please e:mail with your engine serial # for price/availability. We can typically get you a rebuild kit for almost any diesel engine !!! (In/Out of frame options also available)
So maybe they would or could put a kit together for an 03-07 5.9L in or around the same price range. It's one e-mail... it would be worth it to ask.
Old Apr 1, 2010 | 11:21 AM
They have pretty much everything to rebuild the CR's. Here is a link, to the CR upper and lower kit, they only carry genuine Cummins gaskets for the CR's though.
Old Apr 1, 2010 | 12:02 PM
White Ghost's Avatar
i rebuilt mine for about the same as loadhauler 04. it was not that hard . it is just big and bulky and hard to move around.i also added a few extras while i was at it. look in my sig. good luck
azmusclecar
Dec 30, 2007 04:30 PM
cbtumedic
Nov 4, 2007 04:06 PM
srt20
Apr 18, 2007 10:05 PM
Jambbii
Oct 2, 2006 12:37 PM
