HOWES Meaner Power Kleaner is by far the BEST!!!
Please, everyone leave there house right now and go buy HOWES POWER KLEANER Fuel additive. The difference it makes is insane. I noticed my MPG's go down about 2-3mpg when I put the 33" tires about 3 weeks ago. I just added the Howes Power Kleaner and it brought it right back up to what I had and and plus it cleaned my injectors. The best $9 I spent PERIOD!!!
http://www.howeslube.com/products/index.php/category/10
It looks like it can be bought on-line here. I have not checked shipping rates.
http://www.ryderfleetproducts.com/cg...6941&brand=HOW
just put some in yesterday, have been useing redline diesel cat. when towing get a 2mpg increase, go from 10mpg to 12 mpg .i hope howes will impove this by cleaning the injectors or what ever. ordering a xzt box tues so want to get some miles on the howes before i install box to see which one works best.
I use RED LINE it works for me little pricey 60 a gallon but thats treats 1,000 gl. 3 oz per 25 gl. never tried howes. as for mpg who cares what it gets. at least its better than my brother inlaws 1 ton chevy bigblock 4.7 loaded 8 unloaded.
I've been playing around with different additives and so far I feel comfortable in saying Power Kleaner had the best effect on engine noise etc. The engine sounded quieter and felt slightly smoother, like a "well oiled machine".
I can't say what it did for MPG as I didn't measure it.
My question is how often to run the POWER KLEANER?
Do you mix it with Howe's Anti-gel, alternate between the two, only use the power kleaner once in a while....???etc.
I tried calling Howe's to answer this question but never got an answer, not even an machine.
everytime you fill up, USE IT. 4oz=about 32 gallons which is about the size of our fuel tank, which you can see the sizes on the side of the bottle and thats how you know how many ounces you're putting. If I just put $20 in my tank, I also first put like an ounce. ALWAYS PUT THE ADDITIVE BEFORE THE FUEL.
I think I remember the last time I put $20 in a tank, but it sure wasn't ever in this truck.
BTW, I don't like drawing too much attention to my truck by leaving a BA black cloud behind me when I leave the light. Stanadyne Performance really helps keeping the smoke down in midrange take offs.
Off the bottle:
Cummins L-10 Test Rated "SUPERIOR"
4.8% Improvement in Fuel Economy
65% Reduction in Injector Deposits
35% Increased Lubricity- Injectors, Pumps and upper cylinders
80% Emissions Reduction- Stops the smoking
Eliminates & Controls Contaminants in Fuel
Corrosion inhibitor- Stops Corrosion In Engine Fuel Systems
Fuel Stability- Eliminates Sedimant Formation
Eliminates Water
Also use for Farm and Marine diesels
8 oz treats 60 gallons of fuel
I personally use 8oz per 36 gallons of fuel.
Rick
Eliminates Water
Rick
