HOWES Meaner Power Kleaner is by far the BEST!!!
Old Dec 24, 2006 | 01:03 PM
  #31
dieselfan's Avatar
Originally Posted by runamuk
8oz Howes Meaner Kleaner per tank full (36 gallons) Call the number in the first few posts to find a distributor.
http://www.howeslube.com/products/index.php/category/10
Rick
that seems like a small amount for 36 gals. i run 16oz of power service(gray).
what size bottle or jug do you buy?
thanks
Old Dec 24, 2006 | 01:12 PM
  #32
runamuk's Avatar
To the best of my knowledge it is available only in quarts I get 6 quarts at a time.
Rick
Old Dec 24, 2006 | 02:19 PM
  #33
wap's Avatar
wap
Thanks Rick
Old Dec 25, 2006 | 05:25 AM
  #34
lucey's Avatar
Do you use it innconjuction with their conditioner or does it do the conditioning as well ?
Old Dec 25, 2006 | 06:50 AM
  #35
Geico266's Avatar
Rick
Can you buy it on line? Where?
Old Dec 25, 2006 | 10:22 AM
  #36
VikingDiesel's Avatar
no, just the power kleaner itself.
Old Dec 25, 2006 | 10:36 AM
  #37
tacook's Avatar
Might need to give it a try. Thanks for the info
Old Dec 25, 2006 | 12:08 PM
  #38
stang's Avatar
how many bottles do you need to run thru the tank before you see the MPG go up? just want to make sure I give this a fair test. I run Red Line 85+ have not seen MPG go up but I can run my timming up on the TST before I get inj. rattle. but inj noise was still there> How I got my truck to quite down was put a fuel sys on the truck GDP and I thought it had less noise but my wife came outside said your truck sounds like it has less noise what did you do too it? some of the noise might be in the inj. pump (CP3)
Old Dec 25, 2006 | 12:33 PM
  #39
John Faughn's Avatar
When I started using biodiesel , I had some simalar effects , started with 10% , quiter , the exhaust was easyer on the nose & eyes , pluged the filter after 1 wk. , then started using 1/3rd bio and the power & milage went up a little .
about that time I heard that Howes and some others had high % of vegi oil /bio in it , with the simalar results I'm wandering if its true about vegi/bio in Howes .
Old Dec 25, 2006 | 05:32 PM
  #40
bluebull's Avatar
At the mix ratio there wouldn't be enough bio in to make a difference anyhow but I doubt it's bio either.
You can buy Howes at just about any truck stop. Howes and Power Services are major truck stop suppliers.
Old Dec 25, 2006 | 05:49 PM
  #41
Geico266's Avatar
I've checked 2 major truck stops on I80 in Nebraska. They carry Howes, but not the injector cleaner.
Old Dec 25, 2006 | 06:04 PM
  #42
bluebull's Avatar
WOW, that's surprising, Nebraska too. Try a farm supply store or big truck repair shop.
Old Dec 25, 2006 | 06:25 PM
  #43
stang's Avatar
just went to the flying j and got a bottle of the Howes droped it into the aux tank let you know what I think here in a few days or should say few weeks
Old Dec 25, 2006 | 06:30 PM
  #44
you got the POWER KLEANER, right?
Old Dec 25, 2006 | 06:36 PM
  #45
stang's Avatar
yep sure did, not the anti gel
