How to tell the rear end ratio:
Old Sep 17, 2007 | 07:31 PM
woodperson's Avatar
How do you determine the rear end ratio. I know it is on the VIN somehow, but what is the code? Thanks for answering a beginner question.
Old Sep 17, 2007 | 10:05 PM
SSminnow's Avatar
Look in the glovebox, will be there, and no it is not in the VIN number.
Old Sep 17, 2007 | 11:26 PM
nitis's Avatar
what year truck you got my 06 not in the glove box.
do you have a g56 6 speed if you do you got 3.73 yeah I did not believe it either they are that low geared.
Old Sep 17, 2007 | 11:33 PM
stumpjumper's Avatar
jack up rear end. put valve stem at bottom or 6 oclock position. use this to "mark" your tire spin the driveshaft until the valvestem is back at 6 oclock position. if the shaft spun 3 3/4 times you have 3.73 if it spun a "little" more than 4 than you have 4.10
Old Sep 18, 2007 | 08:45 AM
SSminnow's Avatar
Thanks for the tip. I still thought they put it in the glovebox.
And yes, if you ahve the 6 speed (which an 06 will have teh G56) you have the 3.73's
Old Sep 19, 2007 | 12:56 PM
woodperson's Avatar
Not in the glove box.
Let me try again this way. I have the automatic with the OD and the stock tires (michlen) and wheels. At 70 mph in OD I am turning 1900-2000 rpm. Does this sound like the 3.73?
Old Sep 19, 2007 | 06:14 PM
bekim's Avatar
Yes, it's what I run at 70 with 3.73's
Cheers
Mike
Old Sep 19, 2007 | 06:32 PM
j-fox's Avatar
This is true IF both wheels turn the same amount.
If one rear wheel is still on the ground, then you must turn the lifted wheel two full turns.
Old Sep 19, 2007 | 07:20 PM
woodperson's Avatar
Thanks for the info. I was hoping it is a 3.73. I pull a fairly light trailer (6800# loaded) That ought to be a good match. Got the part for the hitch (need to drop it 6 more inches over what I had on the F150 for the Dodge). So when I get it set up I will get to try it with the trailer.
Old Sep 19, 2007 | 09:00 PM
yes the mph and rpm match our trucks with 3.73's.....
webby
Jul 23, 2014 11:08 AM
BoatRick
Nov 19, 2004 10:29 AM
Truckjerk
Apr 26, 2004 11:26 PM
tool
Mar 18, 2004 01:46 PM
Garz
Feb 3, 2003 09:08 AM
