how to remove stock sway bar endlinks
Old Apr 15, 2008 | 09:22 AM
motrapper's Avatar
i will take any suggestions because i tried last night and it was a no go on the dually
thanks
Old Apr 15, 2008 | 09:16 PM
jpfishmaster's Avatar
Just replaced one of mine. Shot it up with some penetrating oil the night before and let it sit. Jack it up, first under the axle to loosen lug nuts; block up axle; then jack up under the frame to take the load off the suspension. Mine loosened right up. Good luck, and be careful.
Old Apr 16, 2008 | 12:49 AM
XLR8R's Avatar
The endlinks come off in a few minutes with a couple of wrenches - no jacking required.
Old Apr 16, 2008 | 04:34 PM
rjm022's Avatar
correct- no need to jack the vehicle- will be easier if you loosen the sway bar frame mount bushings,also. i just replaced mine also- all i did was loosen the frame mount bushings, turned the wheel-pounded out the factory ones and lifted the sway bar off the end link. repeated on the other side- took 30 minutes
megaboom
34
Apr 10, 2008 02:07 AM
tcr
Dec 4, 2007 12:15 PM
Igor
17
Oct 5, 2007 08:46 PM
Dinner
May 29, 2007 02:02 PM
Robert373
Apr 3, 2007 12:20 PM
