How much does a gallon of #2 weight?
Old May 10, 2006 | 11:21 AM
T398's Avatar
NO NO not a gallon of a ford !!!!!
I have heard #2 weighs 8 lbs per gallon but don't have scale to verify. Anyone know???
Thanks, T398
Old May 10, 2006 | 11:28 AM
RustyJC's Avatar
You would think that would be an easy question, but depending on API gravity, I found weights ranging from 6.9 to 7.3 lbs/gallon.
Rusty
Old May 10, 2006 | 11:49 AM
T398's Avatar
Thanks for the reply Rusty. That gives me good base line of where I am with the truck and aux fuel tank full, 135 gal X 7 lbs per gal = 945lbs. Nothing like an extra 900 lbs for the cummins to haul around.
Old May 10, 2006 | 03:06 PM
D.Wiggs's Avatar
Where did you get a 135 gallon Aux. tank ??
Old May 10, 2006 | 03:48 PM
T398's Avatar
Sorry to mis lead you if I did. I have a DEEZEE specialty series fuel tank/tool box combo. It holds 100 gallons, the tool box was about 14 inches deep until I modified it down to 10 inches to make it level with the bed as to not interfere with the fifth wheel. The other was in reference to the 30+ in the oem tank.
One of these days I will figure out the posting pictures thing so I can show you all.
Old May 10, 2006 | 03:57 PM
D.Wiggs's Avatar
Gotcha! I look forward to seeing the pics !
Old May 10, 2006 | 04:01 PM
4x4dually's Avatar
[QUOTE=T398]NO NO not a gallon of a ford !!!!!/QUOTE]
HA! I love it!!!!
Old May 10, 2006 | 04:49 PM
tankeryanker's Avatar
It depends on temperature & gravity. The diesel off our pipeline has been running 54*
34 gravity wt 7lbs 4ounces to the gallon. Gravity drops to 32 & it will run 7.8 lbs to a gallon.
Old May 10, 2006 | 08:42 PM
yfz450guy's Avatar
when i drove long haul i always figured it at 7.5. that way you will be save either way if you need to cross a scale. that covers all that rocket science temp/gravity/humidity/air density and so on.
Purplezr2
Jul 25, 2011 04:31 PM
Geico266
Apr 28, 2010 03:06 PM
gts95
Jun 14, 2009 02:52 PM
Great_big_juan
Oct 1, 2007 01:01 PM
Duallydog
Nov 2, 2006 07:00 PM
