How many miles on a Catalytic Converter
Old May 13, 2009 | 08:27 AM
Fort Ram's Avatar
For those of you that still have one, how many miles should you get before problems arise or you should replace? I have 125k now. Not having any problems I was just wondering?
Old May 13, 2009 | 09:13 AM
cody459's Avatar
After rebuilding my motor at 115k I went ahead and pulled the converter off just make sure it was still alright and to pull parts of my turbo out of it, other than the turbo part It was still ok, went ahead and had cleaned and reinstalled for about a $100.
Old May 13, 2009 | 01:35 PM
Billy Ram's Avatar
I haven't heard of too many stopping up. They just quit working. After removing mine my EGTs went down and my turbo seemed to spool quicker off idle.
Billy
Old May 17, 2009 | 11:25 AM
reax22's Avatar
remove or clean out?
Billy
how do you remove it? Can it be removed and routed out and reinstalled as suggested above? How is this done? Thanks
Old May 17, 2009 | 11:40 AM
Billy Ram's Avatar
I removed mine without any damage but you will need a torch and some help. The factory pulls the clamps down enough to put a good crimp on. If you were planning on reinstalling it I would just sawzall the pipes and band clamp a piece of pipe in its place.
Billy
Old May 17, 2009 | 11:41 AM
cody459's Avatar
When they removed mine the muffler shop cut it at the edge of the pipe and the converter, cleaned the pipe edges, then used some kinda of device to clean out the inner parts of the converter. After cleaning stuck it back up in place welded and it was done, took about an hour.
Old May 17, 2009 | 01:35 PM
NickBeek's Avatar
98K miles on mine and it's not been a problem yet.
If you decide to remove it, I would suggest you take it out intact. Those things are expensive and should you have to put it back, you won't want to buy one. Also if you are dead set on gutting it, then save the internals as there is precious metal in there and you could get a little cash for the stuff.
Old May 17, 2009 | 06:28 PM
Valv's Avatar
If you remove it, will truck be noisier or it will be as quiet as usual ?
Old May 17, 2009 | 06:35 PM
cody459's Avatar
I will be pretty noticeable!
Old May 20, 2009 | 11:41 AM
Coolride's Avatar
Gutted sounds the same to me. Even with my MBRP my truck sounds stock, I don't get these diesels , but put a turbo muffler on a gas truck,and you have the baddest truck in town.
Old May 21, 2009 | 08:55 AM
hotrod929's Avatar
54000...thats how long it lasted on my truck....its sitting in the garage now...
flyingd
Jul 31, 2008 09:39 PM
bobg333
14
Jan 13, 2008 09:33 PM
TXlilbro
Jan 12, 2008 05:32 PM
Txwelder
Sep 27, 2007 07:48 PM
joelmopar12
Jan 23, 2006 11:00 AM
