how to make grid heater cycle all the time
Old Sep 4, 2011 | 11:46 AM
vj_M's Avatar
truck in my Sig, how do i make the grid heater cycle all the time even when the temp sensor reads that it should'nt????
the truck starts way better when i cycle them two times or more but on nice days it wont cycle cuz the temperature is to warm.
will a smarty do this or a bully dog chip?
i know people are going to be asking WHY?
its because a clynder must be weak and its not making heat till the truck get warm.
its cranky to start.
just want to know how to set it up to do this.
Old Sep 4, 2011 | 12:49 PM
Spooler's Avatar
You don't need it unless you are starting to have injector issues. If that is the case, your end result will be a burnt up hole with the offending injector. Not good.
Old Sep 5, 2011 | 07:55 PM
vj_M's Avatar
i've been threw 5 sets of injectos already.. i know what it does when they go.. this isn't do that... its got some blow-by and only likes to start good on warm days.. it always starts but its cranky when the motor is cold.
when i use the grid heater 2 or 3 tines it works great no blue smoke no chugging. nothing...
thats why i want to make them always come on.
Old Sep 5, 2011 | 07:58 PM
Purplezr2's Avatar
Have you done a compression test, sounds like you are trying to band aid the real issue. That said you could rig up a switch to give the solenoids power and an cycle them by hand I imagine.
Old Sep 5, 2011 | 10:38 PM
vj_M's Avatar
ya ur right.. it is a band aid! but it always works so good..
where would i hook a switch to?
is there 2 relays? i know its one on the battery box
2004RAM3500
Dec 4, 2013 09:34 PM
Nor_Cal_Angler
Apr 5, 2010 03:01 PM
Diesel Rover
Jan 4, 2008 03:48 PM
estesbubba
Oct 13, 2006 11:26 PM
Silverjay
Jan 30, 2006 02:18 PM
