Grid heater solenoids cycle repeatedly no start!
I am a little lost on this one. When I turn the ignition on the wait to start light shuts off very quickly and then the solenoids repeatedly cycle and the engine will not start. When I try to pull codes by turning on the ignition 3 times in a row the odometer only shows the mileage, it will not go into code reading mode. Has anyone experienced this? Thanks in advance for any insight you can give me!!
Found multiple loose connections cleaned everything up tightened everything up..........problem solved. I had to have the accelerator pedal sensor replaced a couple of months ago...........it appears these were not retightened when they were done! Thanks for the help BigIron70 made my day!
estesbubba
Oct 13, 2006 11:26 PM
Silverjay
Jan 30, 2006 02:18 PM
