How long does water pump last?
Old Aug 18, 2009 | 05:38 AM
Mark Hodowanec's Avatar
My truck has 120K miles. I just flushed/changed the coolant and am concerned that I didn't get all the air out and that the pump may have been run dry for a couple of miles.
Old Aug 18, 2009 | 08:53 AM
RAMRODD's Avatar
You probably did have a air pocket in the engine that had to work its way out. But I have never seen this hurt a water pump.
Old Aug 18, 2009 | 10:52 AM
Mr Bee's Avatar
I have over 160,000 miles on mine and no issue so far
Old Aug 18, 2009 | 11:24 AM
elirandolph's Avatar
I had to replace mine at 110K.
Old Aug 18, 2009 | 11:31 AM
torquefan's Avatar
Most of them last several hundred thousand miles, but every once in a while, one will die prematurely. When they die, generally it will be pretty obvious. I've never seen one simply stop pumping without any symptoms. They usually start leaking externally, or if the bearing fails they get loose and noisy.
Old Aug 18, 2009 | 09:14 PM
bduncan1231's Avatar
I'm on my 2nd replacement (OEM) waterpump. There's no rhyme or reason to them. It will give you a decent warning that it's going out and they are a very quick fix. Although Dodge wants over 200.00 for them, I believe Genos Garage is CONSIDERABLY cheaper!
Old Aug 18, 2009 | 09:30 PM
roughstock's Avatar
I just replaced my original water pump at 283,555 miles. Not because I had a problem, but because I didn't want to have a problem later. I wouldn't worry.
Old Aug 19, 2009 | 08:05 AM
BarryG's Avatar
My 01 is still using the original stocker at 240k.
Old Aug 19, 2009 | 09:01 AM
cwrhnr's Avatar
My '03 let go right at 107,000, went to blowing out external, made a nice brown mess under the hood. I was in the process of moving the F'ver for an incoming Hurricane Gustav last year.
Old Aug 19, 2009 | 09:41 AM
renninjm's Avatar
replaced mine at around 90,000...started leaking
Old Aug 19, 2009 | 09:51 AM
bnold's Avatar
I ran a WP with an air pocket for probably 10mins .. came back outside and she was squealing like a pig... killed the bearing...
Old Aug 19, 2009 | 07:49 PM
JP-4.5's Avatar
85k mine started weeping... 45k on the 2nd one and still going..
besanders
Sep 23, 2007 10:22 AM
Tommy93w350
Aug 19, 2007 09:31 PM
woodrat
Jan 24, 2007 05:15 AM
12valve@heart
Sep 7, 2005 10:47 AM
AAmeeting
Aug 16, 2005 09:01 AM
