How hot?
Old Oct 11, 2006 | 06:39 PM
wap's Avatar
wap
How hot?
How hot should a manual trans get?
Mine was hot enough the other day I could hold my hand on it for long but it didnt burn me. I know this is not too hot but how hot is?
Old Oct 11, 2006 | 06:45 PM
Elk_Hunter's Avatar
Good question. What type of maintenance do the 6 speeds need?
Old Oct 11, 2006 | 06:57 PM
wap's Avatar
wap
The manual will tell you but I think its every 60k. I just did mine at thirty and cold tell you all about it but do a search for "G56 and tcase oil" or somethin like that I just posted it this weekend.
I used RP synchromax, dont know if I was supposed to or not cause apparently no one one here knew but I guess I will be the test dummy.
Old Oct 11, 2006 | 10:18 PM
Steve034x4's Avatar
From: North of the Frost Line....near Priddis Alberta
The book says ATF+4 for the G56 and same for the transfer case. I change mine every 40k or so km's (about once/year).
Old Oct 12, 2006 | 06:34 AM
wap's Avatar
wap
I know it says ATF+4 but Royal Purple makes synchromax specificaly for manual transmisions and transfer cases that call for atf, so I figured I would give it a try.
Old Oct 13, 2006 | 06:32 AM
wap's Avatar
wap
Anybody????
Old Oct 13, 2006 | 06:36 AM
MikeyB's Avatar
The best way to determine the temperatures is to either install a probe with gauge or use a IR temp meter. My guess is anything above 220 degrees should be a concern.
MikeyB
Old Oct 13, 2006 | 06:46 AM
wap's Avatar
wap
Anything about 220 for a manual?
I highly doubt my trans was that hot. I cold touch it but not more than a few seconds, and my hands aint the hardest I have ever felt.
Old Oct 13, 2006 | 06:47 AM
wap's Avatar
wap
Oh and by the way, thanks Mikey B
Old Oct 13, 2006 | 10:58 AM
T398's Avatar
I have wondered the same thing when towing heavy. I just got my fastcoolers last week but only have about 25k on the redline MTL I put in. Maybe another 5-10k and I'll throw on the fastcoolers and may install a probe just to see.
T398
Old Oct 15, 2006 | 10:41 AM
wap's Avatar
wap
One more time, does anybody have any more info?
Old Oct 15, 2006 | 11:42 AM
CTDinMT's Avatar
T398
I've got Fast Coolers on my truck, and a Commander on it's way. So, in about a weeks I can tell you how hot an NV4500 will get. Manual transmissions are pretty well known for staying fairly cool, which is why most folks don't monitor trans temp on a manual. I would say, IMO, anything over 200 degrees is getting pretty hot in a manual.
Old Oct 15, 2006 | 04:14 PM
wap's Avatar
wap
Please keep us posted.
Old Oct 15, 2006 | 06:01 PM
Equalizer 2's Avatar
I have been running RP Syncromax for about 35,000 miles and have only checked the level. Of course I am running this in a NV5600 and I haven't done anything about checking the temp. As stated there doesn't seem to be much worry (interest) in temps on a manual tranny. As for using the RP in a G56 I am not sure that the oil is properly formulated, I only checked with the makers of the oil for its compatibility for the NV5600.
Old Oct 15, 2006 | 06:31 PM
wap's Avatar
wap
I havent talked to RP personally but it is advertised as, Formulated for manual transmissions and transfercases that call for ATF, and in the manual it calls for ATF+4, so I guess the only thing that kinda bothers me is the +4 part.
BTW I thought NV5600s needed a heavier oil than that, but if thats what they said and you got 35k I reckon its workin.
