How hot?
How hot should a manual trans get?
Mine was hot enough the other day I could hold my hand on it for long but it didnt burn me. I know this is not too hot but how hot is? |
Good question. What type of maintenance do the 6 speeds need?
The manual will tell you but I think its every 60k. I just did mine at thirty and cold tell you all about it but do a search for "G56 and tcase oil" or somethin like that I just posted it this weekend.
I used RP synchromax, dont know if I was supposed to or not cause apparently no one one here knew but I guess I will be the test dummy. |
The book says ATF+4 for the G56 and same for the transfer case. I change mine every 40k or so km's (about once/year).
I know it says ATF+4 but Royal Purple makes synchromax specificaly for manual transmisions and transfer cases that call for atf, so I figured I would give it a try.
Anybody????
The best way to determine the temperatures is to either install a probe with gauge or use a IR temp meter. My guess is anything above 220 degrees should be a concern.
MikeyB |
Anything about 220 for a manual?
I highly doubt my trans was that hot. I cold touch it but not more than a few seconds, and my hands aint the hardest I have ever felt. |
Oh and by the way, thanks Mikey B
I have wondered the same thing when towing heavy. I just got my fastcoolers last week but only have about 25k on the redline MTL I put in. Maybe another 5-10k and I'll throw on the fastcoolers and may install a probe just to see.
T398 |
One more time, does anybody have any more info?
Originally Posted by T398
(Post 1164725)
T398 |
Please keep us posted.
I have been running RP Syncromax for about 35,000 miles and have only checked the level. Of course I am running this in a NV5600 and I haven't done anything about checking the temp. As stated there doesn't seem to be much worry (interest) in temps on a manual tranny. As for using the RP in a G56 I am not sure that the oil is properly formulated, I only checked with the makers of the oil for its compatibility for the NV5600.
I havent talked to RP personally but it is advertised as, Formulated for manual transmissions and transfercases that call for ATF, and in the manual it calls for ATF+4, so I guess the only thing that kinda bothers me is the +4 part.
BTW I thought NV5600s needed a heavier oil than that, but if thats what they said and you got 35k I reckon its workin. |
