How Hard is it to change a belt on a 5.9?
Old Jul 14, 2008 | 12:31 AM
Roperteacher's Avatar
I was thinking of changing out my belt on the 5.9 (07). Staring to squeek a little at shut down. Don't remember doing it before and I have a new belt ready to go... COuld use the OE for a spare. Is it a nightmare to do? Thanks!
Old Jul 14, 2008 | 01:05 AM
Tedonlin150's Avatar
The squeek at shut down is normal. I don't know how easy it is to change though.
Old Jul 14, 2008 | 01:06 AM
24VChevy's Avatar
They are a real pain to change, getting the belt behind the tensioner is the hard part.
Malcolm
Old Jul 14, 2008 | 07:08 AM
Minwy's Avatar
Not something you want to change on the side of the road, if its questionable I would change it at home when you have a nice cold engine and a couple hours to kill. Make sure you start at the A/c compressor and tensioner first otherwise you cant get the belt on all the way.
Old Jul 14, 2008 | 07:16 AM
Jeff in TD's Avatar
I see you have an 07. How many miles are on it? Seems pretty new to need a new belt.
Anyway, there is a TSB to install an over run clutch on the alternator to stop chirp at shut down, which should be free if the truck is under warranty.
http://dodgeram.info/tsb/2006/09-001-06.htm
Changing a belt on one of these is not fun, but not too bad. The tensioner accepts a 1/2" square drive, and is easiest to release from the bottom. To get the belt on and off, it is probably easiest to do the water pump pulley first/last, which is easiest to get to from the top.
If you don't have someone to assist, you may be able to wedge a block of wood between the crank pulley and ratchet handle to hold the tensioner back.
Old Jul 14, 2008 | 07:55 AM
Thanks guys and for the link to the TSB. I just turned 30,000. THought it might be slipping a bit. I will call the dealer and ask about the TSB. Showuld be covered.,
Old Jul 14, 2008 | 12:26 PM
As it turns out, my truck is reacting to Humidity that we don't see ever over here..
Old Jul 14, 2008 | 01:30 PM
nwjetboat's Avatar
Malcolm
What he said. It took 5 mins to get the belt routed correctly, and 20 mins to get it to go behind the tensioner. Not a lot of room in there..
Old Jul 14, 2008 | 01:37 PM
Big3500's Avatar
I also found that having a second set of hands around made it easier.
Old Jul 14, 2008 | 01:39 PM
Sounds like my dealer can do it when it needs it as they probably get to practice all the time! LOL
Old Jul 14, 2008 | 02:36 PM
cincydiesel's Avatar
The chirp is normal a shut down. Its more noticable in the summertime because of the AC compressor. If you feel that is must be replaced its about a 6 pack job. A case if your Madhat but then again he could have it done in one beer. J/K Mad
DodgeDiesel61
Jan 26, 2019 07:45 PM
DodgeDiesel61
0
Jul 28, 2010 11:14 AM
apwatson50
Mar 3, 2006 06:26 PM
jeepsuck
Jan 2, 2006 03:41 PM
s-mcbride
Nov 23, 2005 08:36 PM
