how do i change the fuel filter?
Old Mar 14, 2007 | 12:03 AM
j's Avatar
j
what steps do i take? did it before on my 02', but cant remember how. i know i have to reprime the system. can anyone walk me through it?
Old Mar 14, 2007 | 12:15 AM
ROOSTER108BM's Avatar
https://www.dieseltruckresource.com/...d.php?t=129989
This thread should help...
Rooster
Old Mar 14, 2007 | 03:05 AM
TexasCTD's Avatar
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Here is another.
Old Mar 14, 2007 | 12:42 PM
j's Avatar
j
Thank you gents.... i did the search and didnt find anything like this after looking at the results for about 20 minutes.
Old Mar 14, 2007 | 01:31 PM
VaultRam's Avatar
When it says to bump start....does that mean turn the key to on position for a few seconds and off(repeat 3-4 times)? Or does it mean to crank the starter but not let it start(3-4 times)? Sorry for the stupid question , just thought it was hard on starters to crank them without a start!!
Old Mar 14, 2007 | 03:59 PM
OR Mega Cab's Avatar
Bump start means to just turn the key on and barely bump the starter, about 1/10 of a second. This will make the fuel pump turn on for 15-20 seconds(you can hear it) and prime the empty filter. I did this twice on my filter change and the truck never sputtered a bit when I started it.
Old Mar 14, 2007 | 04:12 PM
bluebull's Avatar
Also leave the key in the on position or else the pump will shut off.
Old Mar 15, 2007 | 01:15 AM
TexasCTD's Avatar
You don't need to bump the starter. Just turn on the key and the pump will prime the system.......(you can hear it). After a while it will shut off, and you can do it again. You are correct above...im just correcting the part about bumping the starter...you don't need to do that.
Old Mar 15, 2007 | 02:46 AM
You dont have to bump the starter but the pump will run longer if you do thereby filling the filter faster.
When key is turned to on position pump will run for 1 to 2 seconds
When key is turned to crank position and quickly released (bumping starter) pump will run for 25 seconds and this is standard procedure in the service manual
Old Mar 15, 2007 | 02:53 AM
TexasCTD's Avatar
OK sorry for any confusion I may have caused. I wonder if there is something different on the 06's vs. 04.5's. I can turn my key on and the pump will pump for about 25 seconds with no starter bump.
jmccart
13
May 27, 2009 09:45 PM
vegashd
Jul 15, 2007 12:24 PM
Lunyfringe
Jan 10, 2005 05:40 PM
doitl8r
Jun 4, 2004 11:14 AM
XTOAK
17
Aug 23, 2003 09:07 AM
