High Idle worked today for the first time
Old Dec 28, 2003 | 12:42 PM
  #31
PROSOUTH's Avatar
From: Dead Center in the Middle of TN. 20 miles from Jack Daniels, 10 miles from George Dickle and .8 mi from the liquor store at I-24 Exit 114
TOOL - Throttle Pedal Depressor
Throttle Pedal Depressor - Perfect for truck warm up, the tool holds throttle at a constant rpm. Engage the nylon hook under the steering wheel. Then, extend the depressor rod to the accelerator pedal. Use the adjustment screw to fine-tune the rpm level. Tools is 40" in overall length.
ID #: LC48700
Price: $24.00
I found this over at GENO's Garage, sounds like a good little stick to have around.
Little stick, not to be confused with the BIG Stick that I also carry. J
Old Dec 29, 2003 | 10:11 AM
  #32
jthorpe's Avatar
DTR Founder
I need something electronic
Old Dec 29, 2003 | 10:50 AM
  #33
vernl's Avatar
I've seen several thing on here about rough high idles etc.. my high idle works great...we had a cold spell and even after a highway run and stopping with the truck at idle, within a few minutes it speeded up with no hesitation or rough running..also when it idles up after a morning start its also very smooth and idles up and down as needed..i would think mine is working the way dodge intended and if others arent seeing this type of result , perhaps a trip to the dealer might fix you up.
cbrahs
May 25, 2012 12:46 AM
CumminsRedneck
Apr 27, 2009 07:56 AM
jmccart
Jun 12, 2007 02:12 PM
Rocky5.9
Apr 12, 2007 09:32 AM
