High idle feature
Old Sep 30, 2006 | 11:13 PM
surfram's Avatar
I brought in a copy of the TSB and they did it for free.
Old Oct 1, 2006 | 03:47 AM
D.Wiggs's Avatar
Originally Posted by no_6_oh_no
It works the same way on the manual as on the auto. Enabled in the ECU and controlled with the cruise. There is a kit available from DC to put it on the manuals that includes a clutch switch and pin and wire for the ECU connector.
So I should just ask my dealer to order the kit ?
Old Oct 1, 2006 | 10:05 AM
moonshinedoc's Avatar
what year models does this include? i have an 04' with an automatic, do i have a high idle?
Old Oct 1, 2006 | 10:18 AM
TonyB's Avatar
I think '04.5 and up. Others will chime in.
Well, you'll have to pay for the kit and install. But they shouldn't charge to enable the high idle .... it'll probably be bundled in with the labor to install the kit
Tony
Old Oct 1, 2006 | 11:18 AM
Festus's Avatar
Tony
Here's my 2 cents on the issue: These manufacturers are on crack - period - and not just DC. They should not even make a diesel pickup without a manually controlled (set by cruise control or otherwise) high idle feature. This should be standard equipment from the factory as should the rear inner fender liners. JMHO.
Old Oct 1, 2006 | 11:28 AM
scottrod's Avatar
My local 5 star told me I would have to pay for the TSB unless there was a problem that the truck had and the TSB would fix.
So, I thought for a second and said my truck won't idle up when it's cold out...
Free high idle install
Old Oct 1, 2006 | 06:09 PM
TonyB's Avatar
Creativity is all it takes!
Old Oct 1, 2006 | 08:24 PM
pet05's Avatar
So what is the purpose of the HIGH-IDLE?
Can you sit in the truck and take a nap during winter (truck being outdoors of course) with this feature?
Lastly, does this feautre INTERFERE with any boxes (Edge or Quad)??
Old Oct 1, 2006 | 08:46 PM
Hercules130's Avatar
Originally Posted by D.Wiggs
So can you have the high idle feature on a 6-spd? Is it used via the cruise control or what?
I had had the switch installed on mine, pretty easy, just need to be comfortably plugging into the ecm. They then can activate using the DRBII.
Old Oct 1, 2006 | 09:17 PM
D.Wiggs's Avatar
So it was like an on/off switch? Or a switch with a dial? What RPM did it take it up to ?
Old Oct 2, 2006 | 02:35 AM
XLR8R's Avatar
Is it just a way to manually enable what the ECM does already if it's cold enough outside?
Old Oct 2, 2006 | 08:35 AM
Smokeman's Avatar
It's a clutch switch...completes the circuit when the clutch is disengaged. RPM goes up to 1100 on activation and can be increased to 1500 with the accel button.
Old Oct 4, 2006 | 03:23 PM
coparam4x4's Avatar
Well just got mine done...$27 for 2 minutes of work and they had my truck for 45 minutes!!! But at least it wasn't the $55 that I was quoted. And they didn't keep my truck for up to 2 day that they told me over the phone. All in all it went a lot smoother than I thought it was going to be. Next on the list is my engine block heater cable as soon as it gets here.
Old Oct 4, 2006 | 05:19 PM
ptgarcia's Avatar
Can someone refresh my memory on how to control the feature? A step by step instruction would be nice!
Old Oct 4, 2006 | 05:52 PM
Smokeman's Avatar
Press cruise on and press set. Truck should idle up to 1100 rpm. Then use accel or decel to set speed from there.
