HELP... Will not start.
Old Nov 30, 2011 | 09:27 PM
HorseBack4x4Gal's Avatar
I have a 2007 3500 5.9 6 speed 2wd 500k. I have an Air Dog pump/filter with block off kit for old filter. Air Dog is working.
OK I replaced the number 6 fuel line because it was leaking. Pulled the boost puller off. I primed it a about 13 times and still nothing. Eng is turning over fine. I pulled off intake and sprayed starter fuild it fired then died. So I know I have a fuel problem but don't know why. I checked all the fuses.
Odd it was running just fine until I changed the number 6 line (that was leaking) and pulled off boost puller.
Is there a chance Batt lost Amps? But I wouldn't think both would.
Not sure what to do here.
All I know have not much cash and need to truck to work in less then 5 days.
Please help???
Old Nov 30, 2011 | 09:44 PM
Spooler's Avatar
Are you getting fuel to the CP3? Is the Airdog running?
Old Nov 30, 2011 | 10:05 PM
Yes to the air dog. Not sure about to CP3. How would I check that?
Old Nov 30, 2011 | 10:23 PM
Adaminak's Avatar
Crack the feed line running into the pump and see if there's any flow when the airdog is running.
Old Dec 1, 2011 | 12:36 PM
Yes there is fuel flow to that point.
Old Dec 1, 2011 | 12:38 PM
Ok for some reason there is no fuel getting to injectors
Old Dec 1, 2011 | 06:54 PM
cdennyb's Avatar
From: In Oroville, Ca., same house for past 46 yrs!
check the electrical connections to the CP3 and make sure any other electrical connectors are firmly seated. Sounds like an electrical not mechanical issue.
Old Dec 1, 2011 | 08:26 PM
PoorMansCat's Avatar
cycle keyswitch 3 times and check for codes...
also, when cranking, does the tach move?
Old Dec 1, 2011 | 09:23 PM
Adaminak's Avatar
Are all the connections in the top of the fuel rail firmly inserted?
TXJClark
Dec 6, 2014 05:50 AM
Hunky Dory
May 13, 2013 08:09 PM
FirstGen1991
Dec 22, 2012 04:24 PM
CoolumConst
Oct 11, 2008 10:00 PM
loosendend
Sep 4, 2006 12:01 PM
