Help! Stranded. Won't start. List of what we've done
Old Nov 10, 2011 | 12:47 AM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Best of luck to you tomorrow...feel free to call me here at the DTR Performance Shop if I can be of any help to you
Old Nov 10, 2011 | 08:45 AM
Lost Lake's Avatar
I know nothing, but a thought I had was to see if anyone else has a heater cord. They are pretty common!
I mean any other trucks. Take one from a plow truck, a passing semi, the UPS guy.... They really are all around.
Old Nov 10, 2011 | 08:51 PM
moparme's Avatar
So the rail pressure can be checked via scanner? What about the return pressure? Just new to the terms of the fuel press test and need to know cuz mine has been sittin for 3 weeks on the long crank time and no start. Have checked the PRV, nothing, FCA is 3 days old and it will start with ether. When running, it is like nothing is wrong and runs well. till I need to start it again....nananananananananananananannnothing!
thanks for the tips
Old Nov 11, 2011 | 12:55 AM
Brian08Q35004x4's Avatar
From: This Nazi state of California 2nd home Gilbert AZ under God
Originally Posted by Brad5502
Isn't there a test port on top of the common rail for a HP gauge?
Truck didn't show any codes for low rail pressure. Last cold hard start two days ago, blew a bunch of black smoke.
Oil was tested 500 miles ago by Blackstone. Not issues at all.
Not sure I'll find a grid heater cord in a part store here in Monterrey...not much demand. I'll call around tomorrow AM. If anyone has one, I'll give it a shot and then keep it under the seat.
See if someone can take you over to Gilroy, but I have never had to
use a block heater or glow plugs in California. The cycling of the grid heater in this climate just ticks me off on the uneccessary drain on the batteries
Old Nov 11, 2011 | 11:50 PM
rich's Avatar
check the torque on the crossover tubes. No way to check return other then flow test. Injectors love to go out in the 03 and 04's. usaully the bodies wear and allow flow back to the tank. you can cap one at at a time and see if it starts to eliminate one bad injector more then one flow test or bench testing is needed.
Old Nov 13, 2011 | 10:46 PM
Brad5502's Avatar
Thanks! No longer stranded
Thanks to all your ideas. This was the first Cummins this shop had worked on!! They wanted to change my CP3 for me...no thanks.
I gave them a list of things (which you all recommended) that I wanted checked prior to dropping several grand on a pump!
Finally got them to cap off injectors (only after they called Dodge to confirm this was valid trouble shooting method).
#3, she still wouldn't start. Capped off #4 and she started right up with lots of black smoke.
Special thanks to Larry Ellis who put me in contact with a supplier that could get me an injector in Monterrey, CA!
Just got back to San Diego. She pulled my 5er w/o breaking a sweat!
Old Nov 13, 2011 | 10:48 PM
Deputydog's Avatar
Hey glad you got it running!
jrobe
Mar 27, 2011 09:23 AM
timmytoo
Jul 22, 2009 12:08 AM
justinm
Jan 28, 2009 09:56 AM
Machinos
Mar 16, 2008 01:34 AM
