just broke down on freeway
Old Nov 9, 2011 | 06:17 PM
wakecrazy22ssv's Avatar
fuel oil or both is pouring out of a black tube on the driver side of my motor in 10 miles I have gone through a quarter tank of diesel I am waiting for the tow truck now any help would be appreciated thanks in advance
Old Nov 9, 2011 | 06:34 PM
06RAM2500's Avatar
Injector stuck open, and flooded your engine with diesel. The chance that it's not severely damaged isn't looking too good right now.
Old Nov 9, 2011 | 06:48 PM
Gatorama's Avatar
Hopefully it is just fuel. Were there any strange noises or performance issues just prior? What does the oil dipstick have to say? If the level has risen and the oil smells like fuel, 06RAM2500 is right. If, and I hope this is the case, the crankcase oil is normal, check all the plumbing around the filter.
Old Nov 9, 2011 | 07:14 PM
oil level has risen no strange noises or anything truck was running great
Old Nov 9, 2011 | 07:27 PM
06RAM2500's Avatar
Got really lucky sounds like. As you already know, do not attempt to start the engine. Right now, trying to keep damage at a minimal is really important.
Old Nov 9, 2011 | 07:48 PM
Gatorama's Avatar
Sounds like a bullet has been dodged. Unlike gasoline, diesel will provide at least a some lubrication, slowing the damage. Hope all goes well.
Old Nov 9, 2011 | 09:57 PM
thanks for the help i got towed home drained the pan 8 gals now waiting for abuddy to check things out sometime next p.m.
Old Nov 10, 2011 | 08:08 AM
jhenson's Avatar
HOLY SMOKES....8 gallons !!! Yeah, I'd say it was full enough that it had to find a way out. If an injector was to stick open wouldn't the engine have tried to run away with itself!! Never experienced this myself but seems like that would happen as an endless supply of fuel would have been present to that cylinder/cylinders.
Hopefully it can be fixed easily with a set of stix and not with a tear down and re-build. Keep us posted....I know I'm curious!!!
Old Nov 10, 2011 | 08:34 AM
Lost Lake's Avatar
Fuel /air is combustible, fuel itself not so much. You can easily flood a cylinder and it won't go bang.
Old Nov 10, 2011 | 09:38 AM
going to be working on it tonight. A buddy says maybe a bad o ring so we are taking the injectors out tonight here is hopen.
Old Nov 10, 2011 | 05:13 PM
steelblitzkrieg's Avatar
DTR Detective
If you flooded a cylinder wouldn't the piston go bang? Fuel/liquid doesn't compress well.
I always thought that it was the body of the injector cracking that allowed it to access the crankcase.
Am I wrong?
Old Nov 10, 2011 | 06:39 PM
i do not know but we are taking out the injectors tonight and then sending them in for testing. That is all i know for now. .
Old Nov 10, 2011 | 06:46 PM
06RAM2500's Avatar
What state do you live in? There's a shop right next to Cummins Rocky Mountain in Billings, MT that has a test bench and you won't have to wait a month for them to get tested. Flux or F1, they got a long turnaround time.
Old Nov 10, 2011 | 07:14 PM
that would be great but i am hoping i am still under warranty with my f1s. If not then i will diffidently l00k for someplace to test them thank u. sorry portland oregon
Old Nov 10, 2011 | 07:17 PM
06RAM2500's Avatar
You are running F1's.
Little tip, if you could, please. Fill out your signature, this way we know what equipment your running (stock and aftermarket).
