HELP QUICK---Fuel Filter Cap Thread problem
Old Sep 25, 2008 | 10:51 PM
ID2500Ram's Avatar
My first fuel filter change on my new (used) 06 diesel. The fuel filter cap will not thread back on the canister. What could I possibly be doing wrong? The o-ring is new and the threads just won't catch at all----no cross threading, no any kind of threading. HELP!
Old Sep 25, 2008 | 10:58 PM
chipmonk's Avatar
are you sure you removed the old o-ring?
4WHEELEX's Avatar
mine is always a little hard to start but a good push and twist should get her started (might hve to do this a couple times good luck
Old Sep 25, 2008 | 11:02 PM
ID2500Ram's Avatar
Yep, old O-ring is off and the new O-ring isn't even close to seating on the top of the new canister until the cap makes a couple turns after it threads. Been pushing pretty hard but didn't want to force it to cross thread.
Old Sep 25, 2008 | 11:09 PM
Colo_River_Ram's Avatar
With age comes the cage
Try turning the cap backwards why gently pushing down on it, when you feel it pop into place try tightening it.. And yes I have a spare one on hand in the shop..
Old Sep 26, 2008 | 12:03 AM
ID2500Ram's Avatar
Got with more pressure.......thanks guys.
Old Sep 26, 2008 | 07:18 AM
MikeyB's Avatar
Yep, I have to press down to get the cap to start threading.
Also don't forget to lube the new o-ring with oil!
MikeyB
Old Sep 26, 2008 | 07:27 AM
MRoman's Avatar
I see you already got it but the cap should tread on with light pressure. Did you clip the filter to the top of the cap before you put it back in? My first change I just dropped the new filter in the canister and tried to put the cap back on. I eventually got it on but it wasn't easy. The second time was a breeze after I found the procedure on this forum
Mike
VFDFireman
Jan 5, 2008 06:47 PM
sterling
Oct 19, 2007 05:32 PM
ajpulley
Jan 16, 2006 04:21 PM
rjrkihap
Oct 4, 2005 05:09 PM
GlennRMK
Jul 22, 2005 10:57 PM
