help please Im lost
Old Sep 1, 2008 | 06:47 PM
red1977's Avatar
help please Im lost
OK got a 05 cummins the smarty is off it and the quad boost fool er. the only thing that is in it is the stage 3 injectors and the turbo. the truck ran fine last night now all of the sudden its like its in limp mode doesn't want to accelerate at all my egts are really high. the fass pump seams to run longer the usual when i turn the key on with out starting it. i just replaced the map sensor a few weeks ago. any help would be appreciated. thank you
Old Sep 1, 2008 | 06:51 PM
mishkaya's Avatar
Just a guess, but have you checked your rail pressure relief valve? I wouldn't be surprised if it were leaking. This sounds like the same symptoms I had on my '05.
mishkaya
Old Sep 1, 2008 | 06:56 PM
Totallyrad's Avatar
You've got a Smarty, check for codes, maybe that will shed a little light.
Old Sep 1, 2008 | 07:12 PM
red1977's Avatar
no codes thrown and were is the pressure relief valve
Old Sep 1, 2008 | 07:14 PM
06RAM2500's Avatar
It's on top of the rail. There will be a line with a banjo fitting, underneath that!!
Old Sep 1, 2008 | 07:22 PM
red1977's Avatar
thank you going to look at it right now I'll let ya guys know
Old Sep 1, 2008 | 08:23 PM
red1977's Avatar
no leaking at all but i am going to go check the ac wire thing that every one is talking about.
Old Sep 1, 2008 | 08:29 PM
mishkaya's Avatar
You probably won't see any leaks as it returns fuel directly to the tank if I recall correctly. If you have a rail pressure gauge you will know, or if you cap it and the symptoms go away you will also know.
mishkaya
SuperiorRam
Mar 15, 2007 03:10 AM
toy4xchris
Oct 23, 2006 12:52 PM
abarnar1
May 11, 2006 10:42 PM
txbubba
Aug 24, 2005 09:07 PM
jimjawz
Jun 15, 2004 12:22 PM
