help with Long crank/starting issues FCA questions
Old Feb 6, 2009 | 11:42 PM
RonP's Avatar
OK folks, I need some input. I have searched quite a few threads and didn't see what I am looking for unless I am just too dang tired.
I left NC about 5pm Fri evening for what should have been about a 5.5 hour trip to PA (ended up being 7). The truck was running super as usual and I was motoring along well. I stopped around Bluefield at a rest area on 77 and when I got back in the truck it just cranked and cranked. it wouldn't even attempt to start.
I thought I was going to have to get Larry from DTR to rescue me.
I tried removing the RP gauge from the rail and the MP-8, heck I even put smarty back to stock and she still wouldn't crank. I must have tried for 30 minutes or more. Finally I said the heck with it and hooked evrything back up and jumped in and gave it a few more tries. Finally I just held the key to start and figured eventually the batteries would die. Well after a constant 30-40 seconds of cranking she fired up.
I drove the rest of the way and never shut it off and the thing ran super, got great mileage and seemed normal.
I did notice it seemed like my rail pressure was quite a bit more erractic than usuall. sometimes it was jumping 3-5k at a steady cruise and when pulling away from a stop it seemed way less linear than usual if that makes sense.
When I got here, I shut it off and tried it again. it started but is taking longer to crank for sure. I will try it in the morning. So would a bad/going bad FCA do something like this? does it have anything to do with starting?
oh, I have plenty of low side pressure if it matters.
thanks folks
Old Feb 6, 2009 | 11:46 PM
madhat's Avatar
Administrator/Jarhead
I hear that the two can be related. There also was a long crank TSB out, I don't think that it would apply to this, tho...
I have my stock one if you want my OL to send it to you so you can trouble shoot it... just send it back...
Old Feb 6, 2009 | 11:48 PM
RonP's Avatar
Ok I must be tired. There are a bunch of posts about the FCA. sorry guys. It seems like it could probably have something to do with it. I will read more tomorrow.
Madhat, I may take ya up on that if I have too. I appreciate it.
Old Feb 7, 2009 | 12:19 AM
madhat's Avatar
No worries. Just PM me with your addy, and I'll have the wife send it to you when she gets a moment...
Old Feb 7, 2009 | 05:49 AM
Asher's Avatar
are you sure your lift pump is working??? Drain the fuel canister and see if just cycling the key fills it up... these trucks will run without a lift pump but might take some cranking to get the FP up enough.
Old Feb 7, 2009 | 05:51 AM
MikeyB's Avatar
Ron,
What was your rail pressure during cranking? Low rail pressure will make it difficult to start the engine. And that can be contributed to a number of things, like a dead or dying lift pump, stuck FCA, injectors bypassing too much fuel, etc....
MikeyB
Old Feb 7, 2009 | 06:42 AM
RonP's Avatar
Originally Posted by MikeyB
Ron,
MikeyB
My low side pressure shows 22psi and I can hear the pump working fine and I can feel the pulsing in the line so I know the pump is pumping. I need to look at it more though because I am picking up the low side pressure off of the fitting that comes with the glacier kit on the back of the bowl. That means I am picking it up before it goes through the stock filter and the 2micron filter. I have been wanting to change that.
As far as rail pressue, unless my new gauge is not working right, I have never seen pressure while cranking. As a matter of fact even when things were normal, my gauge shows no pressure until the trcuk is running for a few seconds and then it shoots to about 6k. I just asssumed that was normal.
so I should see movingment on the rail presssure gauge during cranking? it is a new (couple months) dpricol gauge. I have to leave in a few minutes to go start putting the race car motor together so I hope it starts.
Thanks guys
Old Feb 7, 2009 | 06:54 AM
RonP's Avatar
ok truck fired right up like normal. leaving to work on race car. I will report back later. I hope it continues to start.
Old Feb 7, 2009 | 04:58 PM
homewrecker's Avatar
The gauge won't show pressure while cranking.I have a new fca you can use to verify if its faulty or not.I'm not very far from you.I'll send you a pm with my number.
Old Feb 7, 2009 | 06:34 PM
2007 5.9's Avatar
Might also want to check the relief valve on the rail..I was chasing a long crank issue and found it to be the rail valve blown. Capped it off, and started perfect ever since.
Puke
Jun 29, 2015 05:46 PM
SUPRDUD
Jan 18, 2013 10:33 PM
Planetcat
Oct 25, 2009 09:17 AM
Megaramasaur
May 5, 2008 05:58 PM
draskobnsf
17
May 29, 2007 08:29 PM
