Help with A/C shutting off...
Old Jun 30, 2005 | 12:31 PM
BUZZB8Z's Avatar
A few weeks ago, I got into my truck and began driving out of my neighborhood and within the first 1/4 mile, the a/c just shut off all by itself. I played with all the switches but nothing happened. I made a brief stop and when I got back in the truck, all was fine and has been for the last few weeks.
Yesterday, my truck sat in the parking lot all day and when I got in it to head home...no air again and the switch was on. Again, I made a stop and when I started it up the a/c was back on and seemed to be fine. Just before I made it home, it failed again while driving. This morning all has been fine...???
My switches on the dash are aftermarket billet *****. I did play around with them to make sure they weren't stuck but could find anything outside of normal.
The easy answer is to take it to the dealer but I have concerns about all the mods I've done. I've got gauges, Bully Dog downloader, air intake and hose, lift, exhaust, etc. I know to re-download the stock settings but, will they freak out at the dealership because of the air cleaner???
Anyone have any advice???
Chad
Old Jun 30, 2005 | 12:42 PM
TRAVIST's Avatar
Chances are the problem lies in your control head will isnot and should not be affected by any of the mods that you mentioned above. I would just take it to the dealer and let them fix the problem. After all that is why there is warranty.
TRAVIST
Old Jun 30, 2005 | 01:31 PM
BUZZB8Z's Avatar
I realize that this is a warranty item that should be covered without question. What I didn't want is for them to red flag my truck in their computer systems due to the alterations.
Chad
Old Jul 2, 2005 | 06:07 AM
handymantim's Avatar
Two things come to mind:
1. It is low on freon. When the freon gets low, the low-pressure cut-out switch turns off the compressor to save it from chewing itself up from lack of lubricant.
2. Wide open throttle cut-out switch. I'm not sure if our trucks have this feature but most cars do. Did you have your foot to the floor when your A/C cutout?
Old Jul 11, 2005 | 11:44 PM
hoser's Avatar
Is there still good airflow from the vents..if not , then the evapotator is freezing off...seen it a few times on these trucks.
Old Jul 12, 2005 | 05:35 AM
The freeze problem occurs after about 1 hour of driving.
Old Jul 12, 2005 | 12:10 PM
BUZZB8Z's Avatar
I've messed around with all my ***** (aftermarket *****) and it did seem like one was a little sticky. A minor adjustment and all has been fine since.
I guess it's gonna be a wait and see game.
Thanks for the help guys.
Chad
newconcorddodge
Jul 9, 2008 05:55 PM
RowJ
Nov 29, 2004 06:17 PM
RonP
Oct 3, 2004 02:16 AM
popeyesides
Sep 12, 2004 12:21 PM
Dodgezilla
Feb 6, 2003 12:56 AM
